Hello, how can I make this? I need to author a dvd. I need that every track pauses at the end of it. I mean its usually skip to the next track or to the menu, but I need it pause at the very last frame a stay there for a while. How on earth can i do this?
One way is to to a screen grab of the window while the video is playing and insert that at the end of the video by using the "slideshow" authoring option aith an app like Vision Express or DVD Movie Factory that supports mixing still images and videos on the same DVD. During authoring you can set the timer for whatever length of time you want.
By the way, when you post a topic, try to use a more descriptive title than just "Urgent Help Needed" please. That doesn't give people the slightest hint about what the issue is. Thanks -
I read the whole damn post and still don't know what the issue is.
SLICK RICK....Originally Posted by lordsmurf -
Originally Posted by SLICK RICK
Another method would be to create a silent WAV file (or include music if you wish) using Windows Sound Recorder for the length of "time-delay" you need, then muxing this with the still image of the last frame, then appending this MPEG to the main MPEG.
If in doubt, Google it. -
Cap's method is probably the easiest way to do it. So you take a screen grab of what you want. Make it a jpg. Another program you can use for this is slide show movie maker. Import your jpg and set the # of secs to what you want. Export it, it will be an avi. Then convert that to mpeg 2 and merge it onto the end of your other mpeg file.
Video Compression - Urgent Help needed!
By dberm22 in forum Newbie / General discussionsReplies: 4Last Post: 16th Sep 2011, 10:37 -
[urgent help needed] audio decoding error
By dc0yy in forum Video ConversionReplies: 2Last Post: 26th Aug 2011, 12:47 -
Urgent Help Needed to Save My Video Data
By lovehumanity in forum Newbie / General discussionsReplies: 1Last Post: 21st Mar 2011, 06:30 -
Urgent help needed pls. converting mp4 to xvid- cant get sound
By prendersparty in forum ffmpegX general discussionReplies: 4Last Post: 14th Sep 2010, 13:35 -
urgent - advice needed! date stamp
By devdev in forum Capturing and VCRReplies: 3Last Post: 22nd Jul 2010, 16:53
