Hi,
I am trying to use Canopus Procoder and it is not working for me. I am trying encode a file into XVID. I installed the official XVID codec and when I set everything up. The Program crashes after 12 seconds of the first pass.
Anybody else had this problem or use XVID with Procoder.
Thanks for the help,
Vegas
Results 1 to 9 of 9
procoder will not encode into xvid - it is not even listed as an option ..
if you are trying to encode a xvid file into something else .. ffdshow ussually works better to decode for procoder - but you may have better luck frame serving it into procoder anyhow ."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
he said xvid --- he didnt ask about divx
Hi,
Thanks for the responses. Procoder does have an option for XVID, if you have the Xvid Codec installed. It just crashes after 12 seconds of the first pass.
I use Dr. Divx, for encoding DIVX files, but I wanted to venture into Xvid, as I see it has a better picture quality. -
weird - i have the xvid codec installed and I don't have the option in PC2 or PC1.5 ....
i could do it in Vegas - but 2 pass xvid works better with virtualdub anyway"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
If you choose System -> AVI Target you can select the XviD codec. I just tried it (single pass - quantizer 4) but during the conversion the XviD Status Window remains blank and after a while the conversion simply stops. ProCoder is not locked up because I can still click the Stop button and retry. If I close the XviD Status Window ProCoder also closes. The created AVI file is empty. I gave up after that.
I gave it another try and it worked when I disabled the XviD Status Window (Advanced Options... -> Debug -> uncheck Display encoding status).
However, if I use the InterVideo MP3 encoder from ProCoder VirtualDub doesn't play the audio, but Media Player Classic does. If I use the Fraunhofer MP3 encoder the audio plays in both programs.
Problems with DVD Rebuilder Pro and Procoder 3...
By twangling_jack in forum DVD RippingReplies: 5Last Post: 21st Jun 2009, 18:12 -
Need something besides Procoder that will convert WMVHD to AVI XVID, H264
By godfist314 in forum Video ConversionReplies: 2Last Post: 28th Jun 2008, 18:48 -
Problems with XViD
By trolldown in forum Newbie / General discussionsReplies: 1Last Post: 7th Aug 2007, 16:32 -
Xvid playback problems
By drwho in forum Software PlayingReplies: 7Last Post: 13th May 2007, 21:14 -
3ivX to XviD problems...
By GangstaRap in forum Video ConversionReplies: 8Last Post: 6th May 2007, 11:25
