I've got a video_ts folder created by winavi video converter and then dvd shrink. The original files were downloaded avi files, so therefore there are no chapters or menus created.
What software would enable me to add menus and chapters to the video_ts folder, and then burn the folder which has .bup, .ifo and vob files...and could ezplain how to do it please.
Nerovision Express does not allow me to add ifo or bup fielsand when i add the vob files they appear as 1.68Gb each wen they are 300Mb on my hard drive.
Nero burning Rom allows me to add the vob, ifo and bup files and burn them onto a dvd but i do not know hoe to create menus or chapters as i want to play it in my dvd player. Any help is appreciated
You are better off doing this before you create the vobs, as this make life much easier. Having said that, both Tmpgenc DVD Author and DVD Lab will allow you to import VOBs, add menus and chapters, and create a finished DVD.
This question was asked and answered in the DVD Authoring forum only a couple of days ago. Start here https://www.videohelp.com/forum/viewtopic.php?t=241134 and maybe do a bit of search if you need more details. -
How can you add chapters and create menus before create the vobs, because for me the files are in avi before?
Convert to dvd compliant mpeg, then add chapters/menus in dvdlab (author), then burn.
Cheers, Jim
My DVDLab Guides
Menus & Chapters Multiavchd
By funkyirishman in forum Authoring (Blu-ray)Replies: 4Last Post: 30th Dec 2011, 11:08 -
what program should i use to make some menus with diff chapters?
By shadowofanubis6 in forum Authoring (DVD)Replies: 3Last Post: 28th Feb 2010, 23:48 -
Help with what software is good for menus and chapters
By shashgo in forum Authoring (DVD)Replies: 9Last Post: 3rd Jan 2009, 17:09 -
Making movies with chapters
By dw1 in forum Newbie / General discussionsReplies: 3Last Post: 16th Jun 2008, 07:53 -
Episodes from Several DVD's Onto One With Menus and Chapters
By Savutay in forum Authoring (DVD)Replies: 0Last Post: 12th Oct 2007, 15:41
