  1. I have an old Pentium 550Mhz junker computer that I was thinking about using as a "Firewall". I've heard you can do this but I was just wondering if any of you do it and what you need to do as far as setup?
  2. Master of Time & Space Capmaster's Avatar
    Feb 2004
    Denver, CO United States
    Windows XP has everything you need built-in, except the two ethernet cards you'll need, which are about $6 each online
    We have a machine that acts as a firewall this way on our wired and wireless LAN at home
  3. Член BJ_M's Avatar
    Jul 2002
    Canada
    follow this easy to run guide to install a very good free linux firewall on an system ..
    there are even linux firewalls which can run off 1 single floppy (no hard drive required)
    http://www.zdnet.com.au/insight/0,39023731,20264940,00.htm
  4. I used this for a few years FreeSCO
    Originally Posted by jagabo
    MO, US
    I run a Linux firewall on a 200MHz Pentium. I really don't need anywhere near that much power for the firewall but I also run some database applications and a caching/filtering web proxy on that machine. Most of the people I know use Linux or BSD firewalls for the reliability and ease of maintenance, they take a little time to set up but barring hardware failure you can largely ignore them for a few years at a time.
    A man without a woman is like a statue without pigeons.
  6. Член BJ_M's Avatar
    Jul 2002
    Canada
    there are websites where you do all your setup and it creates the disk for you (that is bootable) ... or other such pretty easy to use setup gui 's ....
