    Mar 2003
    st.louis
    Is there any way tmpg enc plus that you can set it up to do one encode then go to the next file. I have a ton of files built up and need to get them encoded, But Im busy and am not going to be home. If not does anybody know of a encoder that will? Thanks Jay
  2. It will do that. I think it's under "File" and "add to batch encode" (or something like that)...
    Feb 2001
    TMPGENC Batch Mode.
    For each file you're setting up for encode within TMPGENC, save as a seperate project.
    When all are finished, select File\Batch Mode (CTRL+B), and Add the saved projects to the list, then run it when you want to encode them.
    /\/\ars /\/\ayhem
  4. I use the TMPGEnc Batch Encode, but most of the time, TMPGEnc automatically closes itself after first file encoding; that is, I expect it to encode all files in the batch encode list, but the program closes itself after it finishes encoding the first file in the list (or it sometimes closes itself after 2 or 3 files).
    Does anyone know why?
    Thanks a bunch
    Tommy
  5. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    In response to the OP, load your first file, set it up as required, the go to File > Add current project to batch list > MPEG file. It will then ask you for the output filename. After you click the save button, it will display your batch list. Close this, then repeat for each file you wish to "batch". Once you've added your final file, instead of closing the batch list, click the run button to start proceedings.
    If in doubt, Google it.
