I have 2 films... one made in lightwave and exported to AVI
other is made in flash also exported to AVI
both AVIs are compressed with the same codec with same settings
I have reencoded both in TMPGenc to MPEG2, then I've tried to merge them also in TMPGenc... but TMPGENC says NOT Compatible with other MPEG....
what the heck.... both encoded to mpeg by tmpgenc....???
anybody experienced the same?
what is the solution??
I tried to reencode them both.. no help...
thanks
of course both have the same settings...
16:9, same resolution, same fps... same all -
why join them? if you are gonna make a dvd just add both separate when you author.
This need to be foolprof... no chapters...no more movies... no menu...
just one film looping...
but I've solved it since... I needed to reencode the one from lightwave... (strange it did not work first, then I restarted my system and now it works... I'd have a question to BVill Gates...
) that has been already encoded in TMPGenc.... why? don't ask...
but now it works...
thanks
TMPGENC encoding problem
By whschlebaum in forum Video ConversionReplies: 0Last Post: 26th Apr 2011, 23:22 -
TMPGEnc Author Keeps Re-encoding
By lostinspace00 in forum Authoring (DVD)Replies: 13Last Post: 8th Apr 2011, 09:16 -
Encoding using TMPGenc 4.0 Xpress
By abdul_sma in forum Video ConversionReplies: 1Last Post: 19th Jun 2010, 08:15 -
TMPGEnc Plus Encoding
By crys94 in forum Video ConversionReplies: 9Last Post: 29th May 2008, 23:23 -
TmpgEnc 3 - stop it from encoding 544x576 ?
By katykaty in forum Authoring (DVD)Replies: 3Last Post: 10th May 2007, 18:06
