  1. Hi
    Yesterday I burned a VCD with no problems, i've got a bunch of Windows Media Files that I want to put on VCD. So I did that as a test and it worked fine.
    So today I get about 6 of these files and go to burn the disk, but what happenes is that for about an hour it says "Encoding Video" then says "preparing items" then a couple of "cashing" items then all it does is save an "image" to my hard drive. That's it. Nothing gets put on the actual CD.
    I have no idea what is going on as it worked fine yesterday. Can anyone give me a few tips?
    Thanks.
  2. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    What program are you using ?????
  3. only_emo_kid
    Guest
    Nero sounds like... you need to select your burner on nero, other wise its just creating an image to your HD like you said...
  4. yeah, i'm stupid!! I don't know what happened because i've been burning with this burner for years and then suddenly it has changed to "image" instead of naming the burner I am using.
    It's all fixed now, guess I should have checked that before posting. sorry guys!
  5. only_emo_kid
    Guest
    /\ yeah, same thing happened to me a few times.... good luck
