How many VCD's can you possibly put onto a dvd+R these are standard dvd movies... Curious how many will fit onto a dvd+R disc, which the movies were created from divx > vcd > .vob's with DVD SANTA.... Thanks!! (sorry if this has been asked elsewhere, I had searched)
Results 1 to 9 of 9
AnonymousGuest
AnonymousGuest
are you serious!? Thats ALOT... these are dvd rips... from movies, that are like 2hrs long... Thats crazy! Any idea which guide you used to be able to put 19 movies onto dvd+R? Thx
*EDIT* Whut is vcd standard spec? Thanks -
I can get 5 to 6 hours of VCD's on a DVD @ VCD spec EXCEPT that the audio has to be 48k vs. 41k
It u use TMPGEnc DVD Author it will change the audio for you automatically and you can author menus just like a DVD.
Tom -
AnonymousGuest
can I ask without sounding stupid, how to find out whut the audio is on my already made .avi file? to tell if its 48k or 41k or whut? Thx
AnonymousGuest
is this the audio correct? (srry for all questions)
48000 Hz
(and... if its not 48k, and is like 41, or 44... how can i change it? Thx) -
You can actually get 7 hours of vcds on dvd-/+r with audio at 48khz 224kbps.Tmpgenc dvd author will change the audio for you.Goldwave will also change it to 48khz.
Putting multiple vobs onto 25g or 50g blu ray media
By xobituaryx in forum Newbie / General discussionsReplies: 1Last Post: 24th Jul 2010, 22:38 -
Invalid DVD / Multiple errors with multiple programs...
By multiplex in forum Newbie / General discussionsReplies: 10Last Post: 6th Oct 2009, 16:50 -
Help putting together a DVD
By Keano16 in forum Newbie / General discussionsReplies: 5Last Post: 30th Oct 2008, 13:56 -
Multiple VCDs in one DVD
By vid_n000b in forum Authoring (DVD)Replies: 27Last Post: 30th Apr 2008, 03:52 -
Putting two DVD's into one
By Victor Hen in forum Newbie / General discussionsReplies: 1Last Post: 14th May 2007, 12:09
