Results 1 to 11 of 11
  1. Member ViRaL1's Avatar
    Jan 2004
    Making the Rounds
    I'm sure this is probably already common knowledge to many but since I hadn't done a great deal of service work on XP machines until recently I just found this out about a week ago. If you have XP Home and haven't set a password on the Administrator account (which isn't normally even accessible under home), you can boot into Safe Mode and log in as Administrator with full admin privileges, including changing the default user's password if I'm not mistaken. I don't know if this is something that they've closed with SP1 or SP2, but I do know that after a clean install from the original XP Home CD, it's still accessible.
    Nothing can stop me now, 'cause I don't care anymore.
  2. 1st thing you do with ALL OSs is rename the admin account and give it a strong password.
    In fact, I rename all built-in accounts. I create a dumby administrator account and limit its access to everything.
    BTW, just as bad is the everyone group having full access to your hard drives. Hackers dream!
    Originally Posted by jagabo
  3. Member ViRaL1's Avatar
    Jan 2004
    Making the Rounds
    The problem is, most XP Home users don't even know the account exists since it's not even listed in the Users section.
  4. Originally Posted by ViRaL1
    I just stumbled upon this the other day. A client of mine recently stated that he didn't want a computer my company was cleaning/restoring for him. When I hooked it up to check it out, there were four accounts, all password protected. As you stated, when I booted in Safe Mode, I was able to log in with Administrator Priveleges, allowing me to delete all accounts save one (which I left as my new account).
    If God had intended us not to masturbate he would've made our arms shorter.
    George Carlin
  5. The real problem is that you can image boot into any XP or
    2k box and reset the Admin account with ease.
    The only way to block is to remove access to all removable media or block soft/hard resets.
  6. Member ViRaL1's Avatar
    Jan 2004
    Making the Rounds
    Image boot? Elaborate.
  7. Banned
    Sep 2004
    Inner Circle of Thought
    This was taken care of months ago, I believe.
    Microsoft released several patches to keep people with a 2000 disc from accessing the admin account on an xp machine.
  8. This was taken care of months ago, I believe.
    I was not aware of that. What about bootable NTFS readers?
  9. Just tried it... failed. You were right Bazooka!
  10. Originally Posted by ViRaL1
    By making or copying a bootable NX image on floppy
    or cdrom to boot into windoze and reset the admin password.
    Most use Isolinux. There are copies avail on the
    net. It will still work on non patched XP and Y2k systems.
    Search for cd040818.zip
  11. Member Treebeard's Avatar
    Aug 2002
    All you need is a tool called CIA commander, then you can access any PC that has a ntfs drive. it allows you to change the pwd of whichever user you want to change.
    Gives a new meaning to physical security of computers.
