  1. Member Blazey's Avatar
    Dec 2003
    New York
    Is there any benefit to eq'ing out the lows in the audio in a video capture and creating an LFE channel with the appropriate frequencies?
    Apparently I feel I need even MORE projects!
    Apr 2004
    Miskatonic U
    What are you using to create the mix and do the encoding ? Vegas has a setting to automatically build the LFE for frequencies below a certain point. As most amps have this type of setting anyway, a lot of studio disks don't bother putting much into the LFE, but the let the amp do the work on the fly.
    If you are desperate for a new project, perhaps you come up with the definative guide to creating a 5.1 mix a stereo source. There seems to be a need for it.
    Read my blog here.
    ha! :P
    I have seen that question crop up aLOT.
    heres the unofficial guide to converting stereo to 5.1
    Step 1: Don't.
  4. Member Blazey's Avatar
    Dec 2003
    New York
    Originally Posted by greymalkin
    ha! :P
    Step 1: Don't.
    Didn't want to do 5.1 - Just 2.1. My speakers are little JVC cubes but my sub is a 10" powerhouse so I thought it might be worthwile.
