Im wondering if there is any setback of renaming .DAT files to .mpg. Is there a disadvantage of doing that then using a software to convert?
also im wondering if that might be the reason why TDA takes about 1 full minute to load up a 400mb video. Ordinarily it would load instantly. In this case after you select file from dialog box, program will freeze.
Then in window task manager, the process will run up to 400,000. The program will also read 'not responding'. When process goes down back to few thousand then the video will load to the edit screen.
I know for a fact it is not ram problem. it is either the file or program, ive heard some others with this problem but no one knows the answer.
There can be issues processing the file if you just rename it. the .DAT is a wrapper for the MPEG1 file, it contains more info than just the the audio/video information.
The best thing to do, and luckily, it's a free solution, is to download ISOBUSTER and use it to extract the audio and video.
Give that methos a try and see if TDA works better with it.
See the beginning of this guide on how to extract with ISOBUSTER.
http://www.digitalfaq.com/convert/vcdtodvd/vcdtodvd.htm -
By default the file name will be whatever it was on the CD, AVSEQ01.DAT, etc.
However, after it is ripped, it will be MPEG1 Video and Mpeg1 later 2 audio. They will not be demuxed, it will still be one file. If you want them demuxed either get TMPGENc and use the MPEG tools to demux or some authoring programs demux. -
i remember using ISO buster before. Something weird happend. I turned them into mpgs, then for some reason, just having ISOBuster installed, messes with the way TDA works.
After i uninstalled ISObuster, TDA worked fine. I cant remembe specific error but that was the problem. That was before i started renaming them.
renaming captured DV from metadata
By loady in forum Capturing and VCRReplies: 2Last Post: 4th Jan 2012, 03:29 -
Renaming video files?
By c4bdriver in forum Newbie / General discussionsReplies: 5Last Post: 19th Mar 2011, 09:09 -
Automatic subtitle renaming
By notme1 in forum SubtitleReplies: 2Last Post: 5th Apr 2010, 14:49 -
Crash on renaming AVI files
By Captain315 in forum ComputerReplies: 10Last Post: 7th May 2008, 06:05 -
bulk/auto renaming
By chewie8008 in forum ComputerReplies: 7Last Post: 18th Feb 2008, 18:11
