Thanks for the info LurkAzusa and averagejoe007.
Too bad you didn't take some pics of your steps during the install of the drainage tube.
Results 241 to 270 of 994
I would suggest, after owning the system for 2 months....If you are not mechanically inclined, or do not have a lot of duct tape, and patience....forget it.
I have both and I love the system. It is a pain in the ass to watch sometimes,watching for tangles.
BUT I would recommend it, for the ink savings!
I originally bought the epson r200 new and i was out of ink (or at least 1 cart) in 2 weeks.
Now... 1-2months later i have only used 25% of the ink originnally supplied with the system. However you decide to set it up, it is funky looking.
best of luck everyone.If you want a printing headache, use CIS on your printer! -
Originally Posted by Denvers Dawgs
yes easily refillable
Dmagic, just open the little door and use a paper clip to fish out the tube. I drilled a hole in the cap, fed the tube through and clipped it inside the cap, so it won't pull out. Then I velcroed it to the back.
averagejoe007 maybe you should try http://www.imageshack.us/
Lurk thanks for the tips. -
Just got mine today HK to Pa in 3 days can't beat that will let you know how the install goes
OK just went to the ebay site...How do I buy this kit? Says auction is over, and I can't find the buy it now icon?
What We Do In Life, Echoes In Eternity.... -
This has already been answered on the last page. -
Hey AverageJoe,
Anyway to repost your pix???? Just wondering, I liked your setup, but just got my system this afternoon.. -
Yea sorry about that I didn't notice that earlier post....thanks Bodyslide....
Just ordered it, hopefully here by the weekend!What We Do In Life, Echoes In Eternity.... -
Anyone tried the Epson Stylus Photo 950/960 CIS set?
He use pigmented ink with it, but the 950 should use dye based as well.. -
damn it got here in 2 days that just sick.....gonna get rolling on the install
Bodyslide or anybody that know this stuff, got a question for ya
I just my css a couple days ago. I did 2 head cleans from the start and printed that color sheet like 3 times and now printed around35 dvds (give or take a couple). Anyways my black ink is down about 1/4th and my other colors are about 1/5th-1/6th. Is this normal to have 1/4th of your ink gone in a couple days. I was reading here and some other guy said that he has 1/4th ink gone and he had it for 2 months. Did i do anything wronge or this is normal. Let me know thanks.... -
Is this in the ink display or the ink tanks? The display will go down then reset at around 25% left. Or after you leave the printer off, it should reset back to full.
Should the ink be that low or, is that normal and also my ink bar on the computer never moves it stays at 100%. (black is all the way on the right of the pic and on the bottem pic
I have printed over 100 DVD's so far and mine is down alillte lower than yours are. I have only had to do 1 head cleaning. It looks normal.
Originally Posted by TOpclass
Your ink levels look great to me. Don't forget, the tanks are not completelly full when you installed the system. You have to allow for the ink in the carts. The black ink will go down twice as fast as the colours. -
MAN!!!!!!!
My R200 is shipping today!! I don't even have it yet and i'm already dying to order this ink kit!!!!!!!!!!!
I wonder how much business this guy is getting just from this thread -
[quote="Noahtuck"]MAN!!!!!!!
Go on, buy this kit, you won't regret it.
I ordered the kit before I got my r300. It has been running now for a couple of months, no problem ( Other than a few minor one's solved using this forum ).
My r300 has never had epson inks in it, I still have them in their sealed packs. Am hanging on to them for a while in case I have to use the Epson warranty. When I am sure the printer is ok will probably sell them on ebay. -
Hi all,
I happened to bump into this forum and reading this CIS. I used to hate injet printers because of the refill costs, and was waiting for a day so something like this (CIS) would come. I needed a printer for printing DVD lables and this forum brought light on to me!!!
As I wanted to do R&D on CIS printing, I did buy a free after rebate R200 printer from Amazon.com when purchased with Digital camera. I then sold the camera and the original Eposn R200 ink cartridges ($50) on ebay.
I then bought the JLW CIS ($95-$50= $45). Install went fine. Now my problems was the routing the tubes and the cartridge holder. The Tubes would keep rubbing on the Printer body and sometimes entangles. This kept me watching the printer while printing was a headache. So i did cut open the top for freeing tubes movement. Also i had to cut the Cartridge holder so that would mount and lock itself.
Now the printer works perfectly smooth, nothing to worry about . Also to keep the tubes held cut and use a UPS(very sticky and good) or fedex packing pouch to keep the tubes perfectly held.
Some talked about evoparation of the ink from Air Vents. What i did was kept the CIS bottles unit in a box covered with thermal protection foam and made a small breathing opening on the box.
I have some picture i took on my version R200 which i thought i must share to all others who have supported me by this forum
http://www.magprotech.com/r200/IMG_1321.jpg
http://www.magprotech.com/r200/IMG_1322.jpg
http://www.magprotech.com/r200/IMG_1323.jpg
Tip: To cut open on R200 take a stationary knife and heat it and cut it in slow steps. -
Hey guys I need your help.
My light Magenta is no longer printing. I've tried the head cleaning several times. I let the printer sit a day with no luck. I removed the cart and put it back, no luck. Everything was fine until I turned the printer off the other day. I needed to print one more thing so I turned it back on. That was the when that ink was not working anymore.
I don't think ink is being pulled thru the light magenta because I think I can see a small air bubble that never moves. What can I do to fix the problem? -
In this situation I would:-
1. Print a nozzle check
2. Print a 6 colour purge test
3. Tip the ink containers on their side to expel any air ( & then back upright of course )
4. Run another cleaning cycle
5 Repeat 1/2/3
This is just what I would do if I had this problem. -
Yeah, it's done!!!!
One thing though, im guessing this system is gravity fed ?
None of the photo's anyone has posted show it actually hooked up or running, not far enough away to see where they have the tanks during operation.
Epson R200, new cheaper disk printer?
By The village idiot in forum MediaReplies: 309Last Post: 26th Mar 2012, 09:56 -
Win7 drivers for the Epson R200?
By MrSpeed in forum MediaReplies: 0Last Post: 27th Apr 2010, 04:50 -
Looking for a CIS(Continuous Ink System)for an Epson RX580
By Jake802 in forum Newbie / General discussionsReplies: 2Last Post: 19th Jan 2009, 01:02 -
CIS for Epson R260
By Devon05 in forum MediaReplies: 2Last Post: 1st Mar 2008, 01:17 -
R200 + CIS = Problems (any new CIS's I should look at?)
By redfive19 in forum MediaReplies: 0Last Post: 16th Jan 2008, 14:41
