Page 4 of 34
FirstFirst ... 2 3 4 5 6 14 ... LastLast
Results 91 to 120 of 994
  1. Member RickTheRed's Avatar
    Aug 2004
    Up north
    Mikesbytes,
    As requested.
    Here is the JPG.
    Again, please understand that the previous post was photos of photos.
  2. Member mikesbytes's Avatar
    Sydney, Australia
    Have a nice Day
  3. Member RickTheRed's Avatar
    Aug 2004
    Up north
    Oh no!, something's wrong
    I have some problems with the light cyan. I've printed a nozzle check and it's clogged.
    Ok, I do one "head cleaning" and re-checked. Better but still not ok.
    I do another head cleaning and still a bit better but not perfect.
    After two other head cleaning, the nozzle check tells me it's all fine.
    I print a few stuff, and then the light cyan is not correct again
    Is there a way to do a head cleaning with only one color?
    Do I need to clean something "print head" with alcohol?
    Is there a problem to do so many head cleaning?
    I have remarked that this has started after someone lifted the ink block and the light cyan air filter felled on the counter. I put it back. Maybe the pressure or something. Maybe it's a coincidence.
    Any suggestions are welcome!
    ps: I never leave the print on very long.
  4. Try to let it sit overnight.
  5. Aging Slowly Bodyslide's Avatar
    Feb 2002
    A Different Timeline
    Have you tried emailing JLWsales for an answer?
  6. Member RickTheRed's Avatar
    Aug 2004
    Up north
    Thanks but forget it. I don't understand.
    I have just opened the printer and printed a nozzle check.
    The light cyan is 100% back
    The problem started when I printed alot of covers at best photo quality. Maybe there's a link.
    Toronto, Canada
    Hi everyone,
    I just installed my JLW system and has a couple of questions. Does the ink tank have to be higher than the printer? I noticed the tubes have air on it, when I raised the tank, the ink would go in, but when I lowered the tank to the table, the air ink would go back into the tank. I only printed a couple of pages before I had to go to work so I don't know if this is a big deal. I'll be doing more test print tonight.
    Thanks for any information you can provide!
    Toronto, Canada
    Hi,
    I forgot to ask one more question. The ink level, after installing it, was less than full. I turned it off and on and it is still on the same level (for all 6 colors). It hasn't reset to full. Just wondering if you have the same experience.
    Thanks again!
  9. Member bidefordboy's Avatar
    Nov 2004
    Treasure Island
    No, leave your tanks on the table next to your printer, obviously you will have remembered to remove the tank caps & replaced them with the filters. Run the cleaning cycle a couple of times & it should be fine. Have just this weekend installed the system in my r300 using the same setup as 'tonyiws' with the cross support, only I have my tanks on the left hand side of the printer. Don't worry, when the Epsom ink monitor goes just below a quarter full the ink levels will shoot back up to full again. Been doing a lot of printing this weekend.
  10. Member RickTheRed's Avatar
    Aug 2004
    Up north
    Are they doing so one by one?
    I received the standard "low ink level must order new one" message when the black level was below 20%. I've tried sssc utilities but it didn't work. I unplugged the printed while it was on and only the yellow came back at 100%
    How does it work exactly?
    Toronto, Canada
    Thank a lot for your replies. I was beginning to think there's something wrong.
  12. Member bidefordboy's Avatar
    Nov 2004
    Treasure Island
    Did not receive this message when my cartridges got low, they just shot back to full again. Try pushing the cartridges down firmly again to make sure they are making good contact with the chips. Also I have the cover on, bit fiddly to install the cartridges through the hole but you can do it, also the fixing pad on the front of the black cartridge will have to be gently pulled forward to get the cover to close. The levels come back individually. My sequence was:- black, light magenta, magenta, yellow, then after a clean both cyan's together. Try lifting the carts out again & re-insert making sure that they 'click' into place. If that does'nt work could be a faulty chip.
  13. Member tonyiws's Avatar
    Nov 2004
    Florida, USA
    I never received the low ink message using the with the jlw chips. The ink level seems to reset automatically when it is below 20% (estimated.) You don't need to turn the printer off for the ink levels to reset.
    ***Now that I think about it, I may have turned off the low ink level warning when I was still using the regular carts. One of the chips that came with my system was defective, so I'm using a regular (nonreset) chip on one of the carts. I'm pretty sure it's below 20% now and I haven't had a low ink warning on that cart either. You may have to turn it off.
    @bidefordboy: Can you post some pics of your setup?
  14. Aging Slowly Bodyslide's Avatar
    Feb 2002
    Just bought the system and one refill for $169.00. Should be here by 12/13. I will use the advice in this thread to hopefully have a smooth time.
  15. Member tonyiws's Avatar
    Nov 2004
    Florida, USA
    I received a complete new set of chips today from JLW as replacement for one defective one that I had. I just installed it and it is now "recognized" and working great. It seemed to take a long time to get here, but he did send it by airmail and it was postmarked the day he said he sent it. He mailed it 11/25 and it arrived 12/7. I am now completely sastisfied with this system and even happy with the broken engrish customer service. If you're still thinking about getting one, stop putting it off and buy it already. You won't be dissappointed.
  16. Member mikesbytes's Avatar
    Sydney, Australia
    madvideos in you video, the ink tubes are bumping against the case. Is this an issue?
    Have a nice Day
    May 2004
    Augusta Georgia USA
    nope still perfect man. The tubes have not caused any problems at all... the bump as they pass under the casing but not as bad as it looks.
  18. Member
    May 2004
    Augusta Georgia USA
    I did have to duct tape the lid on the carts as the double sticky deal comes loose and keeps the lid from clamping shut. This will cause the ink not to read and make you think you have major probs.
    May 2004
    Augusta Georgia USA
    @RickTheRed .. man your work is good and detailed, I appreciate the info and the pics and the research.
    Thanks.
  20. Member bidefordboy's Avatar
    Nov 2004
    Treasure Island
    @tonyiws
    No decent digital camera yet, but Christmas is coming.
    May 2004
    Augusta Georgia USA
    @RickTheRed
    That took some time to swap carts.. I admire that!!!
  22. Member tonyiws's Avatar
    Nov 2004
    Florida, USA
    @ RickTheRed and madvideos: Am I missing something? I don't see all those pics and vids you guys are talking about. Could you post them here so we can all benefit?
  23. Member RickTheRed's Avatar
    Aug 2004
    Up north
    tonyiws,
    Please look at this thread (video from madvideo)
    https://www.videohelp.com/forum/viewtopic.php?t=247076
    Ok, the problem with the ink level is fixed. I worried for nothing when I saw the epson low level reminder. They are auto-reset chips. They will show 100% after reaching approximately 18% ink level. You shut down the printer (regular shut down) and bingo, the inks level below 18% will reset to 100%.
    Gee, I like this stuff.
    But I have this feeling that someday, the carts will tear apart the tubing, creating a huge color mess :P
  24. Member mikesbytes's Avatar
    Sydney, Australia
    Have a look at this video clip from Ink Republic. They have the tubes arranged differently.
    http://61.219.44.161/InkRepublic/Video/R200/R200-1.avi
    Have a nice Day
  25. Member tonyiws's Avatar
    Nov 2004
    Florida, USA
    @madvideos: My tubing doesn't rub nearly as much as yours. Watching that video was kinda like hearing the dentist's drill.... you know something bad is gonna happen.
  26. Tony, where to buy the clips for tube routing ?
    thanks
  27. Member tonyiws's Avatar
    Nov 2004
    Florida, USA
    thanks
    The only clips that I have on the tubing came on them already. The only extra thing I used was some plastic from a dvd case for the cross support and some hot glue to attach it to the printer. Even the double sided tape came with the kit.
  28. thanks tony, ya they go with the kits, any problem with your tube routing so far ?
  29. Member tonyiws's Avatar
    Nov 2004
    Florida, USA
    No problems with the routing so far. Still seems like the least stressful way to route them. I would still like to see how bidefordboy has his setup. He said he has the ink tanks on the left side of the printer somehow.
  30. Member mikesbytes's Avatar
    Sydney, Australia
    The way that ink republic has the cables routed, means that the tanks would be on the left hand side.
    Have a nice Day
