My tanks if your looking at the printer are located on the right side. The tanks are located on the same level as the printer and about 1/2 inch away from the printer.
Results 271 to 300 of 994
Originally Posted by bidefordboy
*Edit**
I used PhotoShop to print the purge and the light magenta didn't print at all.
Anyone know the steps to manually clean your heads. -
dmagic, go here http://forum.ozmods.com/ , go to the Epson problem's & fixes, first item.
Or here http://photography.about.com/gi/dynamic/offsite.htm?site=http://eddiem.com/photo/print...og/unclog.html
Or here http://www.fixyourownprinter.com/kits/epson/K70
Noahtuk, go to page one, plenty of photo's there. -
LOL!!!!!
I see this and im like, i've looked through this thread.... i don't remember any photos on page 1....
Cool!!!!!!
Thanks & to Bodyslide also....
It would not have been a problem if it was gravity fed, just wanted to make sure so i could put another shelf above my printer before the kit came to save time, figured it might help with the lines not getting bound up or in the way also.....
Originally Posted by dmagic1 -
rite, I received mine last week. I have not got a screw driver small enough to take the screws from the catridge holder thing. is there anyway you can keep it on?
Open cartridge cover, hold the carts in your left hand ( fan them out slightly like you would a pack of cards ) close to the front of the holder & carefully insert each cart, one at a time, through the opening, starting with the yellow cart. When the carts are in position make sure they are pushed down till they lock in place. Carefully close the cover & gently pull the plastic clip on the black cart towards the front to allow the cover to close. On my system I have moved the clip so that it overlaps the black & cyan carts, with the top left end of the clip resting against the cover. Just take your time doing this & everything should be fine. I think it's best to leave the cover on, then you are sure the carts won't work loose over time.
Bad news.
I have found that it is not my head thats clogged but the light magenta cart of the cis. Now what? I've tried shaking the cart. I'm trying to figure out a way to force pull some ink thru the cart to unclog it. Any suggestions would be great. -
dmagic, How long have you had the CIS?? You got yours from JLW Sales right? Have you tried emailing him (think it's Dong Dong) and see what he suggested? Maybe he'll send a new cartridge!? Man hope this isn't things to come, I haven't even installed mine yet...
Yeah, I just emailed him just before I posted. I had it since late November. I'm really hoping he or someone can help me get it unclogged. I don't expect him to replace it after this long but I guess anythings possible.
Have you tried soaking the head in a solution of ammonia/water? Or even just windex? I read that works good.
Here is one tip I found http://www.discount-inkjet-cartridge.com/faq.html . They say to use distilled water, but I have read other's that have used ammonia & water as suggested by ' bdgriff '. Hope you solve your problem & let us know for future reference.
Hi all,
Here is nice to take complete control of your R200 CIS ink system.
http://www.ssclg.com/epsone.shtml
SSC Service Utility
for Epson Stylus Printers.
Downloac this tool,
http://www.ssclg.com/download/sscserve.exe
I hope it is useful to all R200/R300 users. -
Dmagic, you being one of the earlier adopters of the JLWSales system I'm curious to see how your light magenta cart problem is panning out.
Have you refilled your tanks? If so, what ink did you use?
Keep us posted.Fast, Cheap, Good: Choose any two. -
Yes I've refilled my tanks several times. I print a ton of disc and pictures. I've only used ink from MediaStreet.
I've heard back from JLWSales. They gave me some steps to take to unclog the cart. I didn't completely understand them so I'm waiting to hear back from them again. They also stated that if the cart can't be unclogged, they sell a replacement cart that can be attached.
by JLW
The system is design to be easy maintenance if there is any problem. -
Plug-N-Play ink found here
http://www.mediastreet.com/cgi-bin/tame/mediastreet/ink_bottles.tam?&case=epson#order -
I just joined the crowd today, and man o man is this a great system. I have two questions that perhaps someone can address (I couldn't find them earlier in the posts).
1) The tubing has some air in it. Is this a problem or should I just use it without worry? I don't want to do massive cleaning cycles since I'd be wasting all the ink in the tube ahead of the bubbles. Perhaps I can wait, see if there is an issue with the specific color/tube with air, and use SSC to clean just that color...thoughts?
2) I've noticed that my photos are a bit dull or washed out when printing on premium glossy photo paper (compared to prints using the Epson inks). Has anyone found some good settings on the R200 that compensate? I assume we can fix this with some brightness, contrast, saturation changes on the slider bars.
Thanks for the advice and happy printing. -
@klrbee,
1) you don't have a choice. Clean head is the only way to get rid of bubble. Two or three and you should be fine.
2) I don't understand why you try to print something while there is still air in your system. I have compared picts and they are not dull at all. Run the nozzle check and perform clean head until it's totally correct. Also run the print alignment.
@ Dmagic,
Have you notice any difference when you switched to another branded ink? Do you also print photograph?
Thanks. -
Thanks for the reply. I just ran the cleaning and it sucked the bubbles right out. I suppose I'm just being overly stingy with preserving ink...the days of tiny cartridges are finally over and I have to get used to it!
As for dullness, I suppose it's a color profile difference I'm noticing more between my monitor and the print. I think someone said they use the apple srgb with some good results. I've been using the epson r200 output profile. What has everyone else found to work best with this ink/printer combo? -
Originally Posted by scott_tigerHave a nice Day
Originally Posted by RickTheRed
The good news is that I believe I got my light magenta unclogged.I say believe because I still don't have a solid pattern when I check. I'm now seeing ink move thru the tubes, something I wasn't seeing before on that one. That's a good thing. I'm going to let it sit for a while then check it again.
I did a lot of stuff to this cart so I'm not sure if the last thing I did fixed it or a combination of all things. After trying every thing I finally decided to stick a very small precision screw driver thru the bottom opening. I did that a couple of time then finally I saw ink coming out more freely and air building in the tube. I placed it back and when the printer initialized I could see the air being pulled out easily. -
Originally Posted by dmagic1Fast, Cheap, Good: Choose any two.
I cannot figure this out, is there any other way to set this up with the cover on?
I took the cartridge cover off of mine. Cut a small chunk of plastic near the black cartridge. Then I used hotglue to attach the clip to the black cartridge. Then you can open and close the cartridge cover with no issues.
Epson R200, new cheaper disk printer?
By The village idiot in forum MediaReplies: 309Last Post: 26th Mar 2012, 09:56 -
Win7 drivers for the Epson R200?
By MrSpeed in forum MediaReplies: 0Last Post: 27th Apr 2010, 04:50 -
Looking for a CIS(Continuous Ink System)for an Epson RX580
By Jake802 in forum Newbie / General discussionsReplies: 2Last Post: 19th Jan 2009, 01:02 -
CIS for Epson R260
By Devon05 in forum MediaReplies: 2Last Post: 1st Mar 2008, 01:17 -
R200 + CIS = Problems (any new CIS's I should look at?)
By redfive19 in forum MediaReplies: 0Last Post: 16th Jan 2008, 14:41
