I just bought a dvd & discovered it's on 2 sides. I'd like to make a backup copy so the whole thing is on 1 side. When my grandchildren play them I'd rather they didn't have to turn them over, besides I usually make backups for them to play so they don't ruin the originals. When I tried to decryped with DVD Decrypter the first side went fine but then when I went to do side 2 it said the files were already there as the files on side 2 were named the same as side 1. This did not surprise me but I don't know how to get around it so I can have all the files named right so I can then load them into DVD Shrink & just make a copy of the main movie, which is what I usually do for the kids. I looked in the DVD Backup articles in the left column, but didn't really find anything that would address this particular issue. Anyone ever done this with any success?
backup side1 to folder side1
backup side2 to folder side2
more guides
https://www.videohelp.com/guides.php?tools=&madeby=&formatconversionselect=DVDs+to+one+...or+List+Guides -
Thanks stiltman. That's what I was looking for. I thought that I had seen this info a while ago, but couldn't locate it again.
Thank you too, stiltman. I've been staring at The Man Who Would be King for a few months now, looking for a way to put it on one side without having to use/buy DVDRemake Pro. That MrBass guide for backing up flippers with DVDShrink should do it.
Hrmm... too bad the DVDShrink reauthor function doesn't support menus. Oh well, it still slapped the two pieces together and transcoded it to one side. Works well.
Double-Sided, Dual-Layer DVD media?
By dgpretzel in forum MediaReplies: 22Last Post: 15th Apr 2008, 16:03 -
Dual-Layer Double-Sided DVD's turnover?
By Deisel Weisel in forum DVD & Blu-ray RecordersReplies: 6Last Post: 22nd Nov 2007, 22:23 -
do they sell double sided, single layer dvd's (DVD-10 - the ones you flip)?
By cduval04 in forum Newbie / General discussionsReplies: 12Last Post: 24th Oct 2007, 11:40 -
Double Sided DVD to DVD-R
By craigwojo in forum DVD RippingReplies: 4Last Post: 22nd May 2007, 09:16 -
How do I convert double sided dvd to dual layer dvd?
By acid_burn in forum DVD RippingReplies: 2Last Post: 22nd May 2007, 05:04
