I have a DELL PowerEdge 1600SC Xeon server running Windows 2000 Advanced Server. I know that it's recommeneded that when you switch from a single CPU to dual CPUs that you install the OS and Apps from scratch to take advantage of SMP. My question is, since the Xeon (2.0GHz/400MHz/512K) is seen as 2 logical processors by the server and the OS, will I need to reinstall if I upgrade to a second physical processor?
Nothing can stop me now, 'cause I don't care anymore.
Shouldn't need to. The chipset is configured for SMP wether it's available or not and the operating system configures itself for the chipset. You should just be able to plug in the second CPU and boot.
FB-DIMM are the real cause of global warming -
Yes that would be best. Although 2000 AS will
recognise the 2nd cpu at boot, HT is not a pure
logical unit and is not treated as such by services
although it is reported by device manager. SMP
will work on reboot, but certain config settings
may be missing. This is not an issue with 2003. -
you should really not run HT on your xeons in a true dual system
Correct. But improved HT was implemented with the 3.06B.Originally Posted by BJ_M
so this might soon be a problem simply for old servers. -
your right -- but the DELL PowerEdge 1600SC uses the old style buss and memory interface , so i doubt if any benefit (usually slower) .. that is a real good stable system though ... built like a tank -- at least the 1600 's i have had going back to dual 300's
Sandy Bridge Xeon CPUS - motherboard
By kenmo in forum ComputerReplies: 11Last Post: 29th Jun 2011, 15:02 -
[Solved] Backup software recommendations for a dual boot system
By freebird73717 in forum ComputerReplies: 3Last Post: 17th Nov 2009, 14:19 -
Creating a dual boot system...best way?
By sdsumike619 in forum ComputerReplies: 11Last Post: 14th Dec 2008, 11:30 -
I'm Building a NEW computer - core2duo or dual xeon processors ???
By tug_hill2 in forum ComputerReplies: 5Last Post: 7th Mar 2008, 23:12 -
WinTV Dropping frames w/ new Dual Core AMD 5600+ system RESOLVED
By DAVE440 in forum Capturing and VCRReplies: 4Last Post: 26th Oct 2007, 21:01
