Im backing up a DVD, I used DVDBackup and tried to burn with Toast. There is no sound. I opened the VIDEO_TS folder with VLC, it was fine. How do I get sound on the final DVD? sorry if this is a dumb question, but this is the first time ive had this problem and i do this all the time. Thanks.
You may be trying to burn your DVD in Toast's video mode. The proper way to do it when you have files ripped using decryption tools is to use Toast's data mode (choose the Data tab), then click on the Advanced tab in the drawer and set the format to be "DVD-ROM (UDF)".
Create a new disc in Toast, then drag the VIDEO_TS folder onto it and burn.
MKV2VOB sound problems
By DaxPG in forum Newbie / General discussionsReplies: 7Last Post: 17th May 2010, 15:43 -
Problems with sound on 6ch
By pixiesoft in forum Authoring (Blu-ray)Replies: 3Last Post: 5th Apr 2010, 07:12 -
Sound problems
By maltipom in forum Newbie / General discussionsReplies: 2Last Post: 16th Mar 2009, 13:37 -
sound problems
By deebo in forum Software PlayingReplies: 4Last Post: 9th Aug 2008, 14:43 -
Sound problems
By zewzeq in forum SVCD2DVD & VOB2MPGReplies: 9Last Post: 20th Nov 2007, 06:36
