I have a 4 year old Panasonic DMR-30 DVD recorder. It has never been cleaned.Seems like the picture is not as good as it use to be. Is their a DVD cleaning disc available, if so do they work well. Thanks
Just pick one up from Best Buy or Fry's. They work great. But will not work great ,if the eye in your dvd is gone. Sounds like it.
Line marvingj said. They work good and are about $10 also at Walmart. It couldn't hurt to try it because if your recorder is toast you can use the cleaner on CD players, DVD players, DVD writers, and the new recorder if you end up replacing it.Originally Posted by wbrightwell
We're really dusty here, being a desert and all, and I have to constantly clean the lens on my car CD player or it'll skip all over.
DVD Recorder Cleaning
By Maldez in forum DVD & Blu-ray RecordersReplies: 49Last Post: 2nd May 2012, 06:42 -
cleaning dvd's
By the_shyguy in forum MediaReplies: 25Last Post: 7th Dec 2009, 04:39 -
Cleaning a DVD??????? Best way???
By vbond0071 in forum Newbie / General discussionsReplies: 19Last Post: 24th Mar 2009, 18:33 -
Cleaning up a Noisy DVD
By Sliztzan in forum EditingReplies: 4Last Post: 9th Dec 2008, 10:51 -
Cleaning Up Audio On A DVD-R
By spliffy in forum AudioReplies: 0Last Post: 17th Apr 2008, 19:55
