is there anyway for me to take a video that is in wide screen format and put it in full screen............can you do it with tmpegnc program , also what is the size to fit the tv screen the 720 x 480 or 352 x 480
If you want to cut a widescreen to fullsreen select under Settings->Advanced under Video Arange Method: No margin(keep aspect ratio) and TMPGEnc will then cut left and right so it will fit FullScreen. You may have to use Advanced->Clip frame in TMPGEnc also...it depends if your video has visible black borders.
You can use 720x480 or 352x480(better if your source has a low frame size), both will be stretched so it look okey on all TVs.
Does a DVD have to be compliant, as far as screen size?
By snafubaby in forum Authoring (DVD)Replies: 8Last Post: 24th Oct 2010, 23:18 -
Different screen size with different browsers
By disturbed1 in forum FeedbackReplies: 5Last Post: 27th Nov 2009, 05:10 -
DTV converter box, screen size-related question
By Ai Haibara in forum DVB / IPTVReplies: 6Last Post: 22nd Nov 2008, 18:18 -
16:9 Screen Size Question
By SCDVD in forum Newbie / General discussionsReplies: 1Last Post: 10th Sep 2007, 18:43 -
what screen size for video in phone???
By askformore in forum Portable VideoReplies: 1Last Post: 6th May 2007, 19:24
