Dear all
I saw guide how to add menuto a DVD without reauthoring with DVD lab pro and It seems very compicate for me ....
My problem is I authored a group of videoclip in one DVD and each clip had a name, ex clip 1, clip 2 etc...
To play I have to forward one by one until the desire clip and on a DVD I can store 20 to 24 clips, and it's hard to find ex. clip 18...
With a Menu as below it's more easier to go direct to the desire clip
If anyone can show me STEP BY STEP how to Add a title (clip 1) to the related clip. in one page or 2 pages
ex page 1
clip 1
clip 2
clip 3
clip 10
< Back Next>
page 2
clip 11
clip 20
<back
1000 Thanks and best regards
Alain
use ulead products..a lot easier that dvd lab
any way, as I remember, you make a background then drag and drop a frame from your clip into it. aftre that, you have to link it to the movie. create another background, the same, then you link the first one to the second....and so on.
but as I said, better use ulead products, as movie factory or video studio, easier to use.
Is it possible to add a DVD Menu to a AVI?
By Rayster in forum Newbie / General discussionsReplies: 9Last Post: 7th Aug 2010, 10:47 -
DVD Reauthoring - Removing a menu
By xDarKnighTx in forum Authoring (DVD)Replies: 2Last Post: 2nd Jul 2010, 00:32 -
Program to add a menu to a DVD...
By Soccerman77 in forum Authoring (DVD)Replies: 1Last Post: 14th Sep 2008, 03:45 -
Add a language menu to a DVD
By hellbound in forum EditingReplies: 0Last Post: 6th Aug 2008, 10:01 -
Add menu to existing DVD?
By MilesAhead in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 2nd May 2008, 17:56
