Thanks guys
I used Copy toDVD to burn my DVD files to disk. It worked at treat.
I’m not really complaining as the disk ran basically without error on my Xbox, but I was just wondering
1. How would I put chapters into the disk (2.4 GB’s)? Would I do that by re-burning it with Nero 6 and use the chapter creation function in that package or is there a better way?
2. Is there was a way to clean up the graininess of the downloaded video files (E.g. improve final Quality) before you do the final burn to disk or am I asking the impossible here?
Please let me know if I should be looking in the forum for this stuff.
Thanks again Yowie![]()
You are limited in what you can do. There are some filters for virtualdub and other programs that can reduce the blockiness of highly compressed video, improve the clarity, but you don't have a lot to work with. Depending on how bad the source is, and what type of source, you can get some improvements.
I would look at getting a cheap authoring system like TDA or DVD Lab. You can quickly create menus and chapters for your files and compile them into DVD compliant structures ready to burn. The advantage of these programs is they will grow with you, so as you want to get more sophisticated, you will have the tools at hand.Read my blog here.
Always try to get the best source possible. You can clean up noisy material later, but you can't really "add quality" after the fact
Originally Posted by yowie
Downloads, no. Not much, not really. Crap in, crap out.Want my help? Ask here! (not via PM!)
How Can I Improve my video quality
By legend10 in forum Newbie / General discussionsReplies: 36Last Post: 23rd Feb 2012, 14:01 -
How would you improve the quality of this video?
By choobies in forum Newbie / General discussionsReplies: 0Last Post: 28th Nov 2011, 12:24 -
How to improve the quality of the video
By kemo1000 in forum Video Streaming DownloadingReplies: 2Last Post: 24th Apr 2011, 15:36 -
how to improve video quality?
By George2 in forum ProgrammingReplies: 1Last Post: 19th May 2009, 02:07 -
Low quality video on high resolution screen, improve video quality?
By Nitrius in forum Software PlayingReplies: 4Last Post: 29th Dec 2008, 13:38
