according to http://www.digitalfaq.com/capture/avivsmpeg.htm, I should use about 7mbps to 8mbps for full D1 resolution, but I need to squeeze about 2 hours of video onto 1 DVD-R, so that would not work out. What bitrate would you guys recommend for very little pixelation on video recorded at full D1? I'm using MainConcept to encode the video and using Sonic Foundry Soft Encode to get the ac3 (which will be encoded at 224 kbps).
VBR.
5.5 avg, 8.0 max ... that is the "SP" 2-hour spec.Want my help? Ask here! (not via PM!)
when I typed in 2 hours in https://www.videohelp.com/calc.htm it says the bitrate should be 4853kbps. how would the video be able to fit onto a DVD at 5.5mbps avg / 8mbps max if the max i could go to is 4.85mbps?
You are correct, Lordsmurfs figure probably came from the top of his head and is slightly out. Anyway, do as he suggested, i.e. use VBR encoding with 4800 as the average, 8000 max and chances are it will look fine.Originally Posted by choirislife923
The highest possible, with movie length (in time), DVD capacity and DVD bit rate specs as limiting factors. Use a bit rate calculator to find this value.Originally Posted by choirislife923
/Mats
(Give them a fish, and they will not be hungry today. Teach them how to fish, and they will never go hungry again)
720x540 MPG is reported as 720x480?
By sldvd in forum Newbie / General discussionsReplies: 7Last Post: 16th Feb 2011, 16:39 -
Long-Term Storage - Verbatim DVD-R 16x (MCC) still BEST/IDEAL ?
By quantass in forum MediaReplies: 7Last Post: 29th Jan 2010, 01:14 -
DVD to AVI ideal settings
By jbaruch76 in forum DVD RippingReplies: 11Last Post: 4th Nov 2008, 17:40 -
Ideal DVD Recorder for this job...
By retroborg in forum DVD & Blu-ray WritersReplies: 9Last Post: 17th Sep 2007, 16:29 -
avi (640*480) to dvd (720*480) without black bars....how?
By Mauserman in forum ffmpegX general discussionReplies: 8Last Post: 10th Sep 2007, 13:25
