I've been looking all around for those test signals (the ones with all the lines and numbers, Indian head, etc) on VHS. I can't find any. I've seen them on DVD but what I really want to do is look at the quality of my
(S)VHS VCRs and tuner card. Do these test patterns exist on VHS?
you mean you want a tape of test patterns ? there are many - go to broadcastsupply , they should have some or just make your own ...
I've seen these on eBay for about $20.
I have something else I bought for $50.Want my help? Ask here! (not via PM!)
http://www.itworks.com/products/DVDref-suite.htm
good one here - not to expensive ..
i also have a reference test dvd that i made (it is really good and includes both dvd and hdtv) that i could put on tape."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
You're probably better off using color bars. I could not find the Test Pattern your talking about either on a tape. So I had to end up making one myself off internet. If you can find a test pattern like that, its precious as gold. Good Luck!
If folks are looking to make their own, this page has some nice image files to use.
http://www.execulink.com/~impact/uteslist.htm
Test of various VCRs Image Quality from VHS Tape (Big Pics)
By BrainStorm69 in forum RestorationReplies: 47Last Post: 2nd Aug 2013, 15:58 -
Is there a small test video one can use to test Rec 601 / 709 conversion?
By Asterra in forum Video ConversionReplies: 5Last Post: 19th Jun 2011, 08:28 -
[b][url]TEST! TEST TEST! WHAT"S THE BEST?!!!!!!!111111
By lordsmurf in forum TestReplies: 0Last Post: 2nd Aug 2010, 02:30 -
Test of SUPER-VHS playback quality for various VCRs
By theaveng in forum RestorationReplies: 5Last Post: 20th Aug 2008, 08:09 -
870118 - finding similar patterns
By hamidi2 in forum AudioReplies: 0Last Post: 6th Apr 2008, 08:49
