Hi
I captured TV Footage with WinDVR 3 with SVCD Profile and as there were cormmercials on tv i had clips and i wanted to join them together,so i used TMPGEnc to join the clips.When i combine the clips some clips i will get error that says "No Video Stream" on the clip i tried to combine with others.Is there any workaround this?
Cheers
Clive
Yes, videoredo or mpeg-vcr. Or demultiplex the video and audio and use the free cuttermaran.
Stream Clip fix or equivalent for joining this mp4 file
By nerys in forum EditingReplies: 2Last Post: 16th Mar 2012, 11:25 -
How to stretch longer audio stream to a shorter video stream ?
By ralf07 in forum AudioReplies: 9Last Post: 31st Aug 2011, 22:42 -
Joining HD MOV files from camera & saving as mp4; "Invalid Audio Stream"
By maskingtape in forum Newbie / General discussionsReplies: 30Last Post: 23rd Aug 2011, 12:30 -
Help converting small size but large stream size asf video stream file?
By apple4red in forum Video Streaming DownloadingReplies: 5Last Post: 11th Oct 2010, 11:01 -
How do you separate an AVI file into a video stream and an audio stream?
By VidHunter in forum MacReplies: 2Last Post: 1st May 2008, 03:27
