I AM VERY NEW NOT ONLY TO TV CARDS BUT ALSO COMPUTING, STUPIDLY I THOUGHT ALL I HAD TO DO TO WATCH TV AND CAPTURE VIDEO USING MY PC WAS INSTALL THE CARD AND LOAD THE SOFTWARE. HOW OPTIMISTIC WAS THAT! THE DRIVERS THAT CAME WITH MY JETWAY CARD CRASH MY PC, ONCE INSTALLED THE MACHINE JUST CONTINUALLY REBOOTS. I'VE RESTORED TO AN EARLIER DATE BUT WHAT DO I DO NOW. OBVIOUSLY I'VE LOOKED FOR THE DRIVERS ON THE JETWAY SITE ,THEY WON'T INSTALL PROPERLY. HERES THE QUESTION HAS ANYONE GOT THIS CARD TO WORK IF SO HOW, I'M LOOKING FOR DRIVERS AND SOFTWARE SO I CAN USE IT LIKE IT SAYS ON THE TIN. HERES MY SPECS WINDOWS XP PROF & SP2, AMD ATHLON 64BIT 2.8, ASUS MOTHERBOARD K8V, MSI FX5200-T128 GRAPHICS CARD, MEDION(PIONEER)107D DVD BURNER. ANY HELP WOULD BE APPRECIATED PLEASE TAKE INTO ACCOUNT MY LACK OF KNOWLEDGE. THANKS
Have you contacted the Jetway support directly?
BTW, your capslock key appears to be stuck.You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
You in luck! - I think your card can use the BtWincap drivers. I looked in this list >
http://www.chris-tv.com/cards.html
BtWincap drivers are a lot better than the ones you got with the card (faster/allow more capture resolutions) and should solve all your problems. Get them here >
http://btwincap.sourceforge.net/ -
Ok done that downloaded driver and installed them. Know how do I start using the thing. Sorry to sound so dim but i can't find an idiots guide.
Right, you need capture software. I recommend you download all of these and which one works best with your system - all these are freeware >
1. VirtualDubMpeg2 > http://fcchandler.home.comcast.net/stable/
2. VirtualVcr > http://virtualvcr.sourceforge.net/
3. FlyCapDS > http://www.asvzzz.com/download.htm
3. Xvid codec > http://nic.dnsalias.com/xvid.html
4. Xvid decompressor > http://nic.dnsalias.com/xvid.html
5. huffyUV codec >
http://neuron2.net/www.math.berkeley.edu/benrg/huffyuv.html
6. PicVideo MJpeg codec (commercial) >
http://www.pegasusimaging.com/picvideomjpeg.htm
I personally capture using the virtualdubmpeg2/xvid codec - max bitrate/all other options turned off. (It is important to turn off all other options because otherwise the cpu load will be too high and you will drop frames.)
Also if you are capturing with Virtualdubmpeg2, you may need to set display window to preview mode instead of overlay (if overlay screen is black)
PVR files on a PVR formatted disk
By keithy in forum Newbie / General discussionsReplies: 2Last Post: 22nd Apr 2009, 08:26 -
WinTV-HD software needed (not HVR, PVR, Nova, but for original PCI card)
By cybertheque in forum Capturing and VCRReplies: 4Last Post: 23rd Mar 2009, 00:21 -
Asus PCI PVR-210 FM drivers can't be found for XP ?
By MidnightMike in forum ComputerReplies: 1Last Post: 22nd Jan 2009, 09:05 -
Hauppauge PVR-350 vs PVR-500MCE
By dphirschler in forum Capturing and VCRReplies: 1Last Post: 11th Mar 2008, 09:04 -
PCI/PCI Express 1x usb 2.0 card with 2 internal usb inputs
By SIRCOOKS in forum ComputerReplies: 0Last Post: 24th Jun 2007, 11:58
