I have an epson r200 printer which prints directly on inkjet printable media. however im having an issue here.
I can print fine on normal inkjet printables but i bought these full faced ones which prints closer to the center than the standard type.
There is a template for the standard but for the full faced, i have to specify a value in mm of the inner diameter. I have tried to google it for 40 minutes and cant find it. Can someone help me?
Results 1 to 13 of 13
Have you not got a ruler that you could have measured it with.....Originally Posted by Solarflair
I know google is mans best friend but.....Not bothered by small problems...
Spend a night alone with a mosquito -
Originally Posted by iooi
Don't even imply that a ruler is mans best friend
Disks are different.
There is no standard.
I use 22mm and 118mm for hub printable (Prodisc +R).
Other will use different settings for the same disk.
My next order will be Ritek hub printable and I know I will have to change my settings again. -
Which version is this? I dont have all of those options.Originally Posted by p_l
Run 1.10E and i have all of them.
Ah ha! I was running 1.10A, thanks for that, i was unable to change the inner below 40mm and was contemplating buying discus 3, thats saved me a pretty penny.
You can change the inner diameter to anything you want via your registry. The software wont go below 20mm, but I have core hub labels that will go to 15mm. Copy and paste this to a text file and rename it to .reg extension. Then double click to merge. Start the software and it will now show the inner circle at 15mmOriginally Posted by Annatar
The Dword is what you change. put a number into calc and convert to hex if you don't know by memory...F = 15
Windows Registry Editor Version 5.00
[HKEY_USERS\S-1-5-21-1409082233-1060284298-1417001333-500\Software\CORPUS\EPSON Print CD\Printings]
"Bore"=dword:0000000f -
For some reason, on the Epson America site you can get drivers, but not an updated version of the Epson Print CD software. The only place I've been able to find it is from their Russian site
: http://support.epson.ru/upload/drivertypes/000781/printcd_14ae.zip
How's your Cyrillic? It's from the bottom of this page.
Choose the third one from the bottom if you want it in Russian, or the last one down if you want it in English. BTW, if someone who reads Russian could confirm this it'd be great, 'cause I'm pretty much just giving it an educated guess here.
Inkjet -vs- Thermal
By Nator in forum ComputerReplies: 5Last Post: 19th Mar 2012, 07:08 -
Thermal or inkjet printable? How do I tell?
By bizzybody in forum Authoring (DVD)Replies: 0Last Post: 29th Apr 2010, 01:46 -
inkjet ink useage
By victoriabears in forum Newbie / General discussionsReplies: 3Last Post: 15th Aug 2009, 08:18 -
Question about Verbatim White Hub Printables
By zanos in forum MediaReplies: 3Last Post: 31st May 2008, 11:02 -
DVD+R Inkjet Printables - Harder to find?
By thomseye in forum MediaReplies: 6Last Post: 21st Nov 2007, 19:46
