  1. hey all
    i'm using PVAStrumento to mux my tp/ts files....i want to clip the black borders in tmpg but when i open the ES it says "file cannot be opened or not supported"
    ne1 know why it says this or is there any other program to clip black bordes?
    ne help will be nice
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    you realize that you have to re-encode to do this and your reducing the quality to just remove some borders?
  3. The Old One SatStorm's Avatar
    Hellas (Greece), E.U.
    As BJ_M said, you need to re encode your source to crop / mask the boarders.
    And the best way to feed TMPGenc DVB files, is through the dvd2avi frameserver
    La Linea by Osvaldo Cavandoli
  4. thx guys, yea i realize that you need to re-encode ....i will try to frameserve
