I know that I can create a stripe set OR a mirror set in Disk Management. Is there a way to create a mirrored-striped set using software RAID in Windows 2000 Advanced Server, or do I need a hardware RAID controller to do at least one or the other?
In case you're wondering, yes, I am using 4 identical drives.
Nothing can stop me now, 'cause I don't care anymore.
it only supports 0, 1, 5.
I couldn't find any info on 0+1 or better yet 1+0
Have you tried it? Set up the stripe first then try to mirror them or vise versa? -
Thanks for the tip. Already tried it both ways, neither seems to work. I thought as much but I figured I'd put it out there.
Recording Stream on local computer : Streaming Server Wowza Media Server 2
By iLove in forum Video Streaming DownloadingReplies: 2Last Post: 19th Apr 2012, 17:25 -
Anyone mirrored or saved OGT/CVD subbed test images?
By zinchronized in forum Newbie / General discussionsReplies: 5Last Post: 11th Aug 2010, 23:46 -
Advanced Server Software for Avel Linkplayer 2
By blkhdy in forum DVD & Blu-ray PlayersReplies: 3Last Post: 21st Jan 2010, 17:59 -
Dazzle DVC 170 PAL Problem - 'mirrored' screen
By Glaucous in forum Capturing and VCRReplies: 0Last Post: 25th Sep 2007, 07:58 -
Looking for a device to output signal as second (or mirrored) monitor to TV
By ViRaL1 in forum Off topicReplies: 0Last Post: 29th Aug 2007, 12:33
