First off I would like to say thanks to all who helped me out with the last question I had. Without a doubt the easiest thing I have ever done is scan an avi file with vdub to check for errors and then start up WINAVI and convert to dvd then burn with Nero. NOT A PROBLEM IN THE WORLD WITH THAT.
For those who wanted to know and that may help out some of the newbies.
Now onto my new question:
I have 2 avi files that I converted with winavi to dvd files JUST waiting to be burned with Nero. HOWEVER what I want to do is put to dvd movies on ONE dvd. The problem that I saw was that in Nero when you load the video_ts directory with the dvd files THEN load the next dvd files into it you get duplicate files.....So any recommendations on what to do?
Thanks again for the great help!!
could try this guide http://www.myguides.0catch.com/Guide.html
PhenII 955@3.74 - GA-790XTA-UD4 AM3 - 2x4 Corsair Vengeance@1600 - Radeon 5770 - Corsair 550VX - OCZ Agility 3 90GB WD BLACK 1TB - LiteOn 24x - Win 8 Preview - Logi G110+G500 -
Try my guide here, it will fit 2 movies onto a DVD with a menu, just skip the ripping steps as you already have it waiting
I use it, so I know it works, unless you need subtitles, I'm still looking into that -
dont think they will work....anymore help out there or any other suggestions?
Please someone help me out -
tmpgenc dvd author, add dvd video, and add both video_ts folders.
ulead movie factory, ulead video studio...easy to use and you can do have menues.
dvd lab.
Baldrick....is there a guide that you recommend on this site to use tmpegnc dvd author?
I found what I thought was one...but I have yet to use it.
steptoe...I looked at yours but I didnt catch it all the way.
I still am having trouble joining two..
I tried joining the avi files first but they are of two different formats so that did not work
900min in 1 DVD? Several hours/DVD? Multiple movies or tv-series/DVD?
By edvashas in forum Video ConversionReplies: 17Last Post: 29th Sep 2009, 04:16 -
VHS tape won't rewind in mulitple players
By robjv1 in forum RestorationReplies: 15Last Post: 19th Aug 2009, 18:18 -
Getting movies onto a DVD
By rodeman in forum MacReplies: 3Last Post: 25th Jan 2009, 18:54 -
Editing to match tapes from mulitple cameras of the same event
By SCDVD in forum EditingReplies: 5Last Post: 17th Mar 2008, 19:06 -
1h40min movies became 50min movies after conversion
By oediv in forum ffmpegX general discussionReplies: 1Last Post: 31st Jul 2007, 15:13
