    gold coast, australia
    I have samples I want to use, but i need to get rid of certain intruments for example......1 sample i need the vocals off..............another i need drums and guitar off.
    I know i cant get rifd of them completely, but is there a free and easy way to lower the levels of them?
    Apr 2004
    Miskatonic U
    If you have stereo samples with vocals you need removed, and the vocals are pretty much down the centre, try vocal remover from analog-x. It is a directX plugin, and runs in sound forge, audition etc. It does a good job under the right conditions.
    Otherwise, lots of patient tinkering with gates and EQ.
    Read my blog here.
    Nov 2000
    Canada
    I stumbled upon this piece of shareware today:
    Yogen Vocal Remover
    "YoGen Vocal Remover tries to remove any monophonic components from stereo sound. Quality of vocal removal depends on how songs are recorded and mixed. This software works very well for vocal tracks that are "up in the middle" of the stereo mix. Other placement of the vocal in the stereo field can not be removed. If songs are not recorded in this way, their vocals are not removed at all. This is why some songs work great while others do not. MP3 file support has been added over the previous version. Now it can directly process an MP3 file. So you do not need to convert MP3 files to WAV files anymore. Real-time processing allows you to listen to what a vocal removed song sounds like on-the-fly without having to save the vocal removed data to disk. Unsuccessful vocal removal is mainly caused by music files explained earlier. They are very closely and importantly related with the quality of removal. Therefore you do not expect this software to remove vocals 100% nicely. In some cases, however, it will be useful enough to remove vocals."
    http://www.hitsquad.com/smm/programs/YoGenVocalRemover/
