    May 2001
    Eric
    When using DVDx to create mpg2 files, the default maximum file size is 750M. I have used this in the past, and the resulting files were reported by Windows Explorer to be 747M.
    I load one of these into the SVCD burning program expecting it to say a 747M file won't fit on the 700M disc, but it does with no problem. OK...
    So then I use the same setup to create mpg1 files to burn with Easy CD Creator as a normal data disk (not VCD). Then it reports that the 747M file won't fit on the 700M disk (which makes sense). I try the same file to burn a VCD, and it indicates it will fit!
    I'm sure the answer must be simple, but I guess I'm missing the key.
    May 2001
    Eric
    Actually, the default file limit is 730M not 750M, but the question is the same.
    Any help?
    Jul 2001
    Eric,
    When formatting a disk for regular files, the file system itself using up space for thing s like defining sectors, file alloc tables and the such. These things are not present (well, to a much lesser extent anyway) on a disc formatted for (S)VCD for a video stream. That is where the 'extra' space comes from/goes to.
    That's about as generic as you need to answer your question. If you search the site this question has been asked before with MUCH greater detail.
    Have a good one...
    Munich, GERMANY
    VCDs and SVCDs have different sector formats (2.324) than data cd (2.04.
    So if you calculate for a 80min-CD-R:
    79:59 min = 4799 sec
    4799 x 75 x 2324 / 1024 / 1024 = 797,7 MB VCD/SVCD-Format
    4799 x 75 x 2048 / 1024 / 1024 = 703 MB Data-Format
    You can do that yourself for 74min-CD-R.
    Sector-size on CD-R is 2.352 ! The difference to the various formats is filled up with some info like error-correction and so on. As you can see VCD/SVCD has almost no error-correction. Thatīs why it should be burned with 4x max speed.
    Scratch your VCD and it should be almost unplayable und uncopyable because of the lack of error information. Or make a simple finger print on the surface
    Thatīs the story ...
    regards
    mb1
    May 2001
    Eric
    Thanks mb1, great explanation.
