Please help i cant copy a copy my computer wont even see the disk or play with the software player but it plays fine on the tv dvd player.
can anyone please tell me why.
thanks in advance
Results 1 to 11 of 11
What kind of drive you have ,what are your computer specs,what media are you trying to copy from? If you don't give details we can't help you,also when I want to copy a copy my lite on reads anything with no trouble.
does it read in the the writer you burned it with?
PhenII 955@3.74 - GA-790XTA-UD4 AM3 - 2x4 Corsair Vengeance@1600 - Radeon 5770 - Corsair 550VX - OCZ Agility 3 90GB WD BLACK 1TB - LiteOn 24x - Win 8 Preview - Logi G110+G500 -
Bad media.Originally Posted by paulh129
Standalones are a little bit less sensitive on reading disks.
You could try it on another dvd rom to see if that will read it.Not bothered by small problems...
Spend a night alone with a mosquito -
my friend tried to copy this first and had the same results
i have found out that it was copied on a 1 to 1 mashine -
Just try opening the disk in windows and drag the folder to your hard drive..... If that dont work, you are well fooked and will proberly never copy it.
Even if it was done on a 1 2 1 copier it should still be copyabale as most use std burners.
Also have a look at the top thread....
Sticky: Can I backup a dvd backup?
This may be way off but it sounds like the disc is DVD Ram which only can be read by a few units. My standalone DVD recorder does Ram discs which it can play but can not be read by my Pioneer 105.
DVDFab Blu-ray Copy vs. DVD Copy
By coody in forum Blu-ray RippingReplies: 1Last Post: 11th Oct 2010, 12:33 -
How do i copy dvds onto hard drive and what is best software to copy sav
By bfishwick in forum Newbie / General discussionsReplies: 1Last Post: 13th Feb 2009, 17:29 -
Is copy Sony PSP game same as copy DVD disc?
By coody in forum ComputerReplies: 10Last Post: 15th Dec 2008, 07:26 -
How can I copy a copy-protected DVD and have only ONE VOB file
By Aafour in forum DVD RippingReplies: 3Last Post: 6th Oct 2008, 00:31 -
cannot copy 22.5 Gbyte file with Win XP copy command
By maxtrack in forum Newbie / General discussionsReplies: 7Last Post: 2nd Aug 2007, 14:12
