this is odd.. out of the blue i have started to get mencoder exiting with segfaults and bus errors when trying to encode a dvd-sourced .m2v file ripped with 0Sex. i have successfully encoded these specific files recently, though didn't get the result i wanted and now when i go back and try again it isn't working. here's the output:
/Applications/ffmpegX.app//Contents/Resources/pbpaste | sh
Encoding started on Fri Oct 15 15:25:04 ADT 2004
MEncoder dev-CVS-040904-19:44-3.3 (C) 2000-2004 MPlayer Team
AltiVec found
CPU: PowerPC
Reading /Users/xxxx/.mplayer/codecs.conf: Can't open '/Users/xxxx/.mplayer/codecs.conf': No such file or directory
Reading /usr/local/etc/mplayer/codecs.conf: Can't open '/usr/local/etc/mplayer/codecs.conf': No such file or directory
Using built-in default codecs.conf.
File not found: 'frameno.avi'
Failed to open frameno.avi
Reading config file /Users/xxxx/.mplayer/mencoder: No such file or directory
font: can't open file: /Users/xxxx/.mplayer/font/font.desc
Font /usr/local/share/mplayer/font/font.desc loaded successfully! (206 chars)
success: format: 0 data: 0x0 - 0x61cb4701
MPEG-ES file format detected.
TiVo file format detected.
sh: line 1: 800 Bus error '/Library/Application Support/ffmpegX/mencoder' /Users/xxxx/xxxx/xxxx/xxxx/TITLE01-ANGLE1-VIDEO1.M2V -oac copy -audiofile /Users/xxxx/xxxx/xxxx/xxxx/TITLE01-ANGLE1-AUDIO1.AC3 -ovc lavc -sws 10 -lavcopts threads=2:vcodec=mpeg4:vbitrate=1046:keyint=240:vh q:trell:qpel:vqmin=2:vqmax=8:cmp=1recmp=1
ubcmp=1:v4mv:vmax_b_frames=1:vpass=1 -passlogfile /Users/xxxx/xxxx/xxxx/xxxx/TITLE01-ANGLE1-VIDEO1.M2V.ff.avi.log -ofps 23.976 -vop scale=672:272,crop=720:364:0:56 -noodml -o /Users/xxxx/xxxx/xxxx/xxxx/TITLE01-ANGLE1-VIDEO1.M2V.ff.avi
i'm putting an AC-3 audio track in with the "add audio..." option in the audio tab, then using passthrough for the codec. if i hit "encode" to do the whole movie, i get the bus error described above. if i try with the 5-second test clip option selected, it segfaults in the same fashion.
i've tried re-installing ffmpegx and the binaries but that hasn't seemed to solve my problem. major?
okay, muxing the mpeg-2 and ac-3 files as dvd worked (muxing as mpeg-2 failed with buffer underrun almost immediately). it gave me a .mpg file, which VLC played perfectly, including the audio. opening it in ffmpegx reported:
VIDEO: mpeg-2, size: 720x480, 23.976 fps w/3:2, 9800 kbps. AUDIO: ac3, 48000Hz, 448 kbps.
...which is exactly right. however, mencoder couldn't find an audio track when it began to encode so it just encoded video. this is with the passthrough audio codec selected.
mencoder Bus 16()?? error
By kabuto in forum Video ConversionReplies: 1Last Post: 14th Mar 2011, 04:03 -
never mess with an old guy on the bus
By deadrats in forum Off topicReplies: 4Last Post: 5th Mar 2010, 23:54 -
Unit attention, Power On or Bus device reset occured- With DVD+R DL
By bappida69 in forum DVD & Blu-ray WritersReplies: 15Last Post: 3rd Mar 2010, 19:49 -
Using mencoder to crop and convert .avi to .flv - errors
By brandox in forum Video ConversionReplies: 0Last Post: 26th Jan 2009, 11:09 -
MEncoder errors when copying mpeg2 file
By orev in forum Video ConversionReplies: 2Last Post: 22nd Feb 2008, 14:51
recmp=1
