  1. Which one would be faster?
    Encoding such as divx to mpeg2 cause I do quite a no of burning.
    Someone enlighten me please
    USA
    Probably the Intel by just a little, just make sure you have a lot of spare cash. The AMD chips might be a little slower, but a whole lot cheaper. The encoding speed is very much dependent on which model of either CPU, and to a lesser degree, the memory and the board you are using. Just my opinion.
  3. I read that the AMD 64 3800 runs circles around the P4 3.4 with HT for gaming AND encoding. I was thinking about getting it but its too much $$ for right now....
  4. Член BJ_M's Avatar
    Jul 2002
    Canada
    not a lot of difference ... slight nod to Intel right now but could go either way next time .. what redwudz says is right -- depends on system as a whole and what models you are comparing ..
  5. Член BJ_M's Avatar
    Jul 2002
    Canada
    not at all -- ive got several of each and no diff. for mpeg encoding ..
    can't speak for gaming ..
  6. Member glockjs's Avatar
    Feb 2004
    the freakin desert
    really not too much of a difference, intel has a slight edge. but if you wanna compare your wallet size after purchasing either i would take a good look at amd. as far as gaming, amd no contest.
    PhenII 955@3.74 - GA-790XTA-UD4 AM3 - 2x4 Corsair Vengeance@1600 - Radeon 5770 - Corsair 550VX - OCZ Agility 3 90GB WD BLACK 1TB - LiteOn 24x - Win 8 Preview - Logi G110+G500
    Apr 2002
    Oskeeweewee Ontario
    I think the more important factor is software that supports the full 64bit structure..
    This is where the jump should occur...
    Just an educated guess. :P :P
  8. Член BJ_M's Avatar
    Jul 2002
    Canada
    yea -- still waiting for that - to be out of beta
