Hi everybody![]()
My problem is I have a Yamaha DSP A595 amp which is great for 5.1 dvd's, but when I listen to older (classic) movies, the majority of which are in 1.0 mono or 2.0 mono, I am only getting sound from the centre or the two mains. My amp only does DD, DPL, and a handful of DSP modes, (no DPLII, no Neo6, no CSII) of which, Mono Movie is supposed to be for the "oldies", but I don't like it as it creates a lot of reverb and echo. If I turn it down, there is no effect at all.
I suppose what I'm really asking is, is there any other way of enhancing mono soundtracks so that they sound more "acceptably" surround? or even pseudo? I hate listening to a movie through the centre channel alone.
Thanks very much in advance for any help anyone can give.![]()
Hello,
Does your dvd player support virtual surround?? My sony does (I do have a 5.1 receiver but sometimes I've used virtual). It's acceptable. I haven't tried it for mono movies but you might look into it.
Kevin
EDIT - If you have a dvd burner you could edit it. Rip it to the harddrive. Than extract the soundfiles with besweet. From there you could use any sound editor and "clone" the one channel sound. That should make a fake stereo signal (fake in that its the same signal in left and right but it would show up in both channels). Worth a try.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Hello,
For synching you could just use tmpgenc or tmpgenc dvd author (or another authoring program).
There shouldn't be any issues since your using the source sound. But programs like virtualdub have a sync feature to them (unfortunately virtualdub only converts to avi which would then require a dvd authoring program that accepts avi - since dvd is mpeg2).
Kevin
--good luck--Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Okay, I have ripped dvd to hard drive with Dvd Decrypter.
Ripped audio soundtrack with Dvd Audio Ripper.
Created and Edited 6 Mono sountracks in Vegas 4.0
Now what?
When I save my newly edited tracks they become a Vegas File!
How do I export these elsewhere?
And how do I join them with the ripped vobs from the dvd to create -a new dvd sountrack, so I can burn to a blank with my dvd writer?
Hope this is feasible. If not, please bear with me as I'm only a newbie to all this and am trying my best.
Enhancing a still from video
By jackhandsome in forum RestorationReplies: 58Last Post: 24th Oct 2018, 19:56 -
Video editing and enhancing
By Videographer in forum EditingReplies: 3Last Post: 29th Aug 2011, 19:17 -
music enhancing software
By deadrats in forum AudioReplies: 2Last Post: 25th Jun 2011, 21:06 -
Removing foreign soundtracks from .mkv
By leamingtonspaceman in forum Video ConversionReplies: 2Last Post: 10th Mar 2011, 03:58 -
Multiple language soundtracks on Wombler
By eliserh in forum AudioReplies: 0Last Post: 15th May 2010, 05:20
