Now im sure this is a real newb question and i probably know what the answer is going to be.
I know that when you convert a dvd to SVCD a lot of quality is lost as a result because even 2 cd's cant hold nearly as much as a DVD.
On the other hand a DVD ripped to XViD looks great and at only around 700MB, its half the size of two video CD's.
So my question is, once you have already ripped a DVD to XVid, since its already so small, would there be any loss ripping it to SVCD?
Probably a dumb question i know.
Thanks for any help![]()
Results 1 to 10 of 10
Hello,
You mean xvid to svcd???? There would be some loss anytime you convert something.
Since you have the originals anyway
just rerip to the format you desire the first time. Clean and simple.
I have ripeed one to both formats as a test and like i said the xvid one looks much better than the 2 svcd version.
so if i convert the xvid one to svcd, would it look as bad as if id just ripped straight from dvd to one svcd?
Cuz im thinking that would look pretty bad -
Like Yoda313 saidOriginally Posted by Xander2061
Create SVCDs directly from the DVD not the xvid file. You'll be encoding only once instead of twice. Creating SVCDs from the xvid is like making a VHS tape copy from a copy.There would be some loss anytime you convert something -
It'd look worse, as the original DVD is a better source than the XviD.Originally Posted by Xander2061
/Mats -
Your one CD Xvid looks better than your 2 disk SVCD, is that right? So you want to know if you convert your one CD xvid to a one CD SVCD, will it look better than the 2 disk SVCD made directly from the DVD source, have I got that right?Originally Posted by Xander2061
NO, it will look much worse. The two compression methods (Mpeg-2 and Mpeg-4) are quite different. Xvid requires much less bitrate (data) for a given picture quality than SVCD. Try using the DVD source to create a 3 disk SVCD and see if you like that any better, or stick with Xvid. -
ok bugster, you got it right.
I think ill stick to 2 svcds cuz i think its getting kinda silly with 3 cd's.
I mainly wanted to know cuz i want to make a multi film dvd that has several svcds on it if you know what i mean.
ANyway thanks for your help -
Hello,Originally Posted by Xander2061
Why didn't you say so in the first place???
Here are some guides for svcd to dvd found on the left of the screen:
https://www.videohelp.com/guides.php?tools=&madeby=&formatconversionselect=SVCD+to+DVD&...or+List+Guides
because i know how to do that already, i was asking about xvid to svcd.Originally Posted by yoda313
Thanks for the specific link though
If that is the case, and your source material is coming from DVD, you should encode to 1/2 D1 res (352*480/576) rather than SVCD res as this is DVD compliant and SVCD res is not. It will give you greater compatibility now and in the future. You could still use SVCD type bitrates, or even a bit higher if you have the space. Quality wise you almost certainly won't notice the slightly lower res.Originally Posted by Xander2061
VirtualDub/Xvid question: YV12 vs. XVID FourCC in the xvidvfw.dll driver???
By KneeRow in forum Video ConversionReplies: 14Last Post: 1st Aug 2010, 14:35 -
Does xvid cli (command line version of xvid) actually exist ?
By vhelp in forum ProgrammingReplies: 10Last Post: 29th Oct 2009, 15:18 -
Weird I don't have XviD or DivX codec installed but I can see Xvid movies
By Talayero in forum Software PlayingReplies: 4Last Post: 5th Jun 2008, 12:47 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 10:11 -
Xvid to svcd + burn...
By Crapozo in forum Newbie / General discussionsReplies: 7Last Post: 25th May 2007, 06:07
