I can't seem to find in Ulead workshop version 1.3 if there is an option to control what the play button plays.
Say I have three video clips on the main menu and want the play button to play the first clip and return to the main menu or play all the clips consecutively where would I set this.
Thanks.
You can't, as far as I can tell. And DVD WS 2 doesn't add this function either
Anyone have evidence to the contrary?/\/\ars /\/\ayhem -
By default, the Play button is a play all button, then returning to the menu, but in Menu you can highlight the button, choose the Button tab, select Playlist, and add/remove or change the order of whatever you want it to play.
Thanks for the help. I downloaded the 30 trial of version 2 and I think that the playlist is only an option in this version.
Can I create my own custom Button in TMPGEnc Authoring Workshop 4?
By JackyWang in forum Authoring (DVD)Replies: 4Last Post: 31st Aug 2016, 22:14 -
Does anybody have Ulead DVD Workshop SE 1.21?
By OS_Man in forum Authoring (DVD)Replies: 5Last Post: 21st Sep 2010, 02:04 -
Replacement for Ulead dvd workshop 2
By jakewoodblues in forum Authoring (DVD)Replies: 3Last Post: 14th Apr 2010, 22:05 -
Ulead DVD Workshop 2 with Vista?
By SCDVD in forum Newbie / General discussionsReplies: 2Last Post: 17th Feb 2008, 02:48 -
Ulead DVD Workshop 2 error
By SEE_Studios in forum Newbie / General discussionsReplies: 21Last Post: 4th Jan 2008, 02:55
