Howdy Guys
Ive downloaded a video clip off the web recently but it is not in a playable format. It is in a folder and has 7 of these files called VTS and 3 files called VIDEO TS.
Can someone tell me what Program I need to Recompile it into a playable format, that I can later burn to DVD.
If you could give me a bit of a rundown on how to go about the re-compiling process that would be great.
I dont have any experience with video files. Ive only backed up my own movies with XCopy.
Thanks Yowie![]()
What are the extensions of the files?
Howdy dudes
This is the file layout in the folder. There is basically three rows of files but this dialog box pushes my 3 typed rows together:-
VIDEO_TS VIDEO_TS VIDEO_TS.BUP
VTS_01_0 VTS_01_0.BUP VTS_01_1
VTS_01_2 VTS_01_3 VTS_01_4
VTS_01_5
All of the files apart from the .BUP files have configured themselves as Nero ShowTime files(Nero 6 installed on my system) and the 2 .BUP files look like text sheets.
Does that clear it up?
Thanks Yowie
Try PowerDVD or WinDVD and select hard disk as source. Select the directory that contains those files.
If you want to burn it to dvd read
https://www.videohelp.com/guides.php?howtoselect=3;25#3;25
Newbie Question - H.264 MOV -> Playable HD Format ???
By Rake in forum Newbie / General discussionsReplies: 2Last Post: 6th Dec 2011, 07:31 -
Help convert avi to WD HD Player -Playable format
By anbures in forum Video ConversionReplies: 1Last Post: 7th Nov 2009, 06:27 -
Converting from DVD format to playable on MAC format...
By livvyramone in forum MacReplies: 2Last Post: 23rd Jul 2008, 09:21 -
.MKV to HD Xbox 360 playable format
By gingerprince1965 in forum Video ConversionReplies: 3Last Post: 31st Jan 2008, 12:19 -
Settings to convert WMV to VCD/DVD-playable format?
By pingosimon in forum ffmpegX general discussionReplies: 5Last Post: 16th Jul 2007, 18:53
