  1. If I cut (cut out say 20 seconds) width TMPGEnc DVD Author last remained frame (or frames ?) stops a bit on the burned DVD. The mpeg file has been made width TMPGEnc Plus 2.5 , I tried everything, even to use only I pictures in the mpeg. The DVD material is good. If I cut the same mpeg width Womble MPEG Editor everything is OK. Could somebody give an idea what to do ?
    It would be easier to do the editing width TMPGEnc DVD Author .
    Csaba Fuzi
  2. Member Forum Troll's Avatar
    Oct 2003
    Right behind you
    The internal editor in TDA isn't very good. I found that it causes errors in the GOP stream. Personally I use VideoReDo. It has frame-accurate MPEG editing.
    You are in breach of the forum rules and are being banned. Do not post false information.
    /Moderator John Q. Publik
  3. Member jeanl's Avatar
    Sep 2004
    CA, USA
    I have had the same problem, and didn't find a way around it.
    Jeanl
