Hi, I'm new here. So if I'm doing anything wrong or post anything wrong pls correct me and will avoid it next time.
On with the problems. I have a few music video vcd. I want to put them in one dvd. I've follow the guide using ISOBUSTER to rip the data out of a vcd into .mpg format. but when I to put them in a dvd, it do nothing. I try to author it with SVCD2DVD but it won't start. Can someone pls help? Any help or input is greatly appreciated. Thank you.
Here is the deal. your VCD is (NTSC anyway) 352x240 with 44.1 mhz audio, while an acceptable dvd format is 352x480, 704x480, or 720x480 48mhz audio.
There are applications like movie factory 2, which will allow you to make a "non" compliant VCD-DVD, however you must upsample the audio to 48mhz.
there is a guide that Baldrick has that walks you through the process. If your search for the guide comes up empty, please post back and I will try to locate it for you.
I think another application would be dvdsanta, not sure though. -
I follow this guide from BALDRICK himself/herself [ https://www.videohelp.com/forum/userguides/159399.php ] When I get the .mpg file I put it in SVCD2DVD and try to burn it to a DVD but it didn't work. It just stay there and nothing is being converted. I don't know why. Thanks for the reply Macleod.
here is the one that i was talking about:
https://www.videohelp.com/svcddvdr.htm
course, now looking at it, it is for svcd to dvd.
Here is the one for VCD to DVDR:
http://www.dvd-guides.com/content/view/57/59/ -
Doesn't SVCD2DVD do that? I ripped the 15 chapter of a video cd into .mpg as following the guide I previous post. I then put it in SVCD2DVD to burn it all in a DVD. I have about 3 music video CD and I want to put it all in one DVD. hmm.. But I will try the guide you posted for me macleod, Thanks a lot. I hope there's a different way of doing this in a SVCD2DVD to save me time.
WM Recorder 12.1 won't capture Yahoo music videos
By darrenpj in forum Video Streaming DownloadingReplies: 13Last Post: 30th Jul 2009, 12:28 -
WMP Won't Add My Music?
By Nitro89 in forum ComputerReplies: 3Last Post: 22nd Jun 2008, 06:49 -
Can I burn a music video along with music trax onto the same disc?
By Kalla B in forum Newbie / General discussionsReplies: 0Last Post: 4th Jul 2007, 13:02 -
Video won't convert to Widescreen
By RogMcDodge in forum ffmpegX general discussionReplies: 1Last Post: 12th Jun 2007, 15:46
