I am attempting to convert several different formats of tapes...VHS, Hi 8, DV and so on. Is there an all in one deck/adapter that handles these?
Jason
Results 1 to 9 of 9
Hi jdecker,
What do you want to convert them to? What's your end goal?There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
To what do you want to convert them?
If God had intended us not to masturbate he would've made our arms shorter.
George Carlin -
There is no equipment that can play all those formats,they have to be played in separate players of their own format.
Originally Posted by daamon
Jason -
OK, as johns0 said - each format will require it's own player.
You could look into these for "adaptors":
1. Canopus ADVC-50 (or similar) - takes in various analog sources and digital (DV) and outputs as analog or digital to your PC.
2. Canopus ADVC-100 - same as the 50, but you can do PC back out to external device. The 50 doesn't do this.
3. DataVideo DAC-100 - Different manufacturer, same as 1 or 2 (don't remember which).
You'd want the digital ouput from any one of these devices and use something like WinDV, DVIO or AVI_IO to "capture" to DV AVI.
From there you'll:
A) Edit in your desired editing app - Trim, add effects and or audio.
B) Encode - Turn the finished project from AVI to DVD Compliant MPEG2. Popular encoders (in no particular order):
TMPGEnc
Canopus Procoder
Mainconcept MPEG Encoder
Cinemacraft Encoder
C) Author - Create menus, produce VOB files etc. Various tools, including:
TMPGEnc DVD Author (good start for newbies, fairly flexible)
DVDLab - More complex
Look in "Author" in "Tools" section.
D) Burn to DVD - Nero etc. Some authoring tools do this too.
Hope that helps...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
What I am looking for is the hardware aspect. I have an ADVC-100. I am just looking for a affordable solution to play the tapes without purchasing all of the recorders.
Jason -
Sorry - I can't help you there. I would suspect that johns0 has hit the nail on the head though...
Good luck.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Does such a monitor exist?
By A Traveller in forum Media Center PC / MediaCentersReplies: 13Last Post: 9th Sep 2009, 18:45 -
Exist a .ts analyzer for h264 ?
By Robertus in forum DVB / IPTVReplies: 6Last Post: 21st Aug 2009, 05:08 -
Does this mp3 recorder exist?
By Theresa in forum Portable VideoReplies: 2Last Post: 22nd Jan 2009, 13:40 -
Does This Product Exist?
By Anakin in forum DVD & Blu-ray RecordersReplies: 5Last Post: 26th Dec 2008, 10:09 -
This might exist i couldnt find it
By angrodm in forum Newbie / General discussionsReplies: 1Last Post: 27th Nov 2007, 00:31
