I need to know this really badly, but everyone's ideas don't seem to help. I need a way to transcode a DivX (AVI) file that is about 170MB to a MPEG2 file that is about 300MB and can be burned without transcoding again on DVDit!. The video is about 23 minutes long. I already own DVDit! SE, TMPGEnc Plus, and MainConcept MPEG Encoder. Please tell me how to do this.
Also, I need to fit about 13 of those files on 1 DVD and I need the DVDit! to not say the "not DVD-legal" error because whenever it says that, it transcodes it again and I don't see anything not DVD-legal about what I burn.
Thanks,
Sean
(Sorry if I am posting the same thing over, but nothing seems to help me and I am getting very frustrated...)
Results 1 to 13 of 13
Encode to MPEG2 in TMPGENC.
Then author.Want my help? Ask here! (not via PM!)
Well... thats the problem. When I author with DVDit!, it says that the files are not DVD-legal. I was just thinking of something and I was wondering if it was because the files were 640 x 480. Does it have to be a certain format to work with DVDit! ?
Hi shifted90,
If you look under "What Is... DVD" at the top left of the page you'll se that a resolution of 640x480 isn't valid for either NTSC or PAL DVD.
So, as you suspected, there's your problem...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
During encoding - Have you looked in any guides / forum posts? It's all in there...
Carpe diem.
I can't say - Coz I use DV AVI it's already in the right resolution.
I'd suggest looking up the encoder you're using in the "Tools" section - that may / should / will have a load of guides listed below the main description.
Or, look through the guides directly.
When you get a list of candidates it's gonna have to be a case of reading through and figuring out what's good for you...
Good luck.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Well, I just tried doing it and it didn't seem to be the problem that I am having. I changed the resolution to the right size, but DVDit! said that the file was not DVD-legal and non-compliant. What do I do now?
Originally Posted by shifted90
1. See "What Is... DVD" for specs for NTSC and PAL.
2. Use either AVICodec or GSpot on your file to get info.
3. Compare and act accordingly...
Without my crystal ball, I can't see what error messages you're getting... The more info you post and the more you actively go looking for answers, the more likely you are to elicit detailed responses.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
You know what? Forget about DVDit!. I'm sick of it. I'm going to start using TMPGEnc DVD Author 1.6. It works so much better. Thanks guys.
Whatever works for you is good. No problem.
Good luck...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Some Mainconcept MPEG Encoder questions.
By scott274 in forum Video ConversionReplies: 9Last Post: 15th Jul 2008, 03:08 -
MainConcept MPEG Pro HD Question
By Nuke Shower in forum Video ConversionReplies: 3Last Post: 27th May 2008, 22:48 -
MainConcept MPEG Encoder 1.5 question
By hanugro in forum Video ConversionReplies: 6Last Post: 21st Feb 2008, 20:27 -
TMPGEnc Xpress, MainConcept, H.264 and QuickTime Compatibility
By PuzZLeR in forum Video ConversionReplies: 6Last Post: 27th Oct 2007, 04:05 -
Avi to DVD (mpeg2) in Mainconcept Mpeg Encoder, basic how to
By reboot in forum User guidesReplies: 31Last Post: 6th Aug 2007, 15:56
