Hi!
I finally got the dvdwriter to work and burned the dvd+r I had! And when I tested them on my standalone dvdplayer the did not work properly..
They lagged abit in the meny, and stopped for some seconds..
And when I tried to change the subtitles in the menu the dvd just freezed...
Any suggestions?
I have this dvd player - http://www.samsung.com/Products/DVDPlayer/technicalinfo/index.htm
is says it can play dvd+r
Results 1 to 17 of 17
CrAp!
Without knowing any trivial information such as what programs you used for ripping, encoding, authoring, etc
Buy the DVD!!
Samsung are pretty good at playing most anything you throw at 'em.
Whose media are you using (Media ID as denoted by DVDInfoPro or DVDIndentifier. -
Read. Learn. www.nomorecoasters.comOriginally Posted by macho271
Good luckWant my help? Ask here! (not via PM!)
the MediaID code for that dvdr. use DVDInfo Pro (freeware).media? You mean what kind of dvd+r?
how/what is the setup for your backup process. What media brand are you using. Have you tried to slow the burn speed down to 1x? Does that give you better results.
Ok, I now read the FAQ.. But, "thats write" dvd+r's wasten on that list..
Anyway..
Not tried 1x though, but I only have a 2,4x burner so dont think thats the problem...CrAp!
You didn't read it then.Originally Posted by macho271Want my help? Ask here! (not via PM!)
Media Information
Region information N/A not a DVD-VIDEO
Media code/Manufacturer ID OPTODISCOR4
Media Product Revision Number 00h
Free Blocks 405405696
Free Capacity 4.38GB(4.70GB)
Book Type DVD+R
Media Type DVD+R
Media Id Code Speed 4.0x 5540KBps
Available Write Descriptor CLV 2.4x 3380KBps
Available Write Descriptor CLV 2.0x 2770KBps
Linear Density Blank Disc
Track Density Unknown
Number of Layers 1
This is what i got from the info...CrAp!
The reason I suggested writing at 1x (the slowest speed), the result would help tell you what the overall problem is.
If the dvdr burned and played just fine, my next statement would be that there is a good chance that your hard drive needs to be defragged and that you should do burns from a non OS drive (ie dont burn from your C drive).
If the dvdr doesnt burn right, then there is a good chance that something is up with the media and or the burner.
What did you use to burn the DVD??? If you are using dvddhrink to compress the movie, try and use dvddecrypter to do the burn. See if that helps. -
Come on guys the obvious reason for all his problems is cheap media,buy a better brand and it will fix your problem.
Yes.Originally Posted by louthewizWant my help? Ask here! (not via PM!)
Ok!
But how do I know what dvd+r I should buy?
Concidering buying -> Samsung Pleomax 4x DVD+R 4,7GB 25-pack Cake Box...
But, Have the same problem.. Dont want to spend money, and the dont work.. so Can I check how good they are?
CrAp!
Hi again.. the samsung dvd+r I wanted to buy is OPTODISCOR8
Does that mean crap?
https://www.videohelp.com/dvdmedia.php?dvdmediasearch=Samsung+Pleomax&dvdmediadvdridsea...+or+List+Media
review says its good..!
And, since I have samsung dvdplayer, shoulden that dvd samsung dvd work?CrAp!
Ok, this time.. **** the cheap discs.. For twise the amouth I spent on thats write dvd+r's, I now want to try RITEK!
I read this review, and it seems that they work fine..
https://www.videohelp.com/dvdmedia.php?selectmedia=280#comments
But, Im still a littlebit skepticaly to buyin new dvds.. 25$ is not something you want to just throw away!CrAp!
buttons on JVC XV-N50 dont work
By schlep in forum DVD & Blu-ray PlayersReplies: 5Last Post: 11th Jan 2012, 23:59 -
Trouble with audio from mobile. Used to work fine. Dont know what happned.
By UmmAddan in forum AudioReplies: 5Last Post: 6th Jan 2010, 10:13 -
Restored videos dont work!
By BVG in forum Video Streaming DownloadingReplies: 5Last Post: 7th Jan 2009, 20:50 -
DVD menus and RTMs dont work right
By shashgo in forum Authoring (DVD)Replies: 0Last Post: 20th Dec 2008, 13:54 -
Remotes dont work under MCE 2005
By Annex in forum Media Center PC / MediaCentersReplies: 3Last Post: 12th Jun 2007, 08:30
