I've captured directly from my VHS-C camcorder and have gotten good results. I was thinking of purchasing the JVC 9800 S-VHS. Will I get better results using the adapter tape and capturing from the JVC VCR instead?
probably not. If the max resolution of the VHS-C is say 352x480, getting a S-VHS tape player wont make it any better.
The time base corrector and DNR features of the vcr would help you to get the best possible picture from your source. But it will not improve the resolution.
Steve -
I got the JVC 9911u and the TBC and digital noise reduction circuit does help. When I turn it off or on, it is very noticeable that it helps stablize the picture.
If you have a capture device with S-Video, then the S-Video on the JVC would help get the clearest picture possible. On several of my tapes I notice a difference. The S-Video has a crisper image with less color bleed. -
Be careful using those "C" adapters inside of JVC machines. They are usually not TRULY tape size, so the JVC is just going to EAT YOUR TAPE. be careful.Originally Posted by lolmos69
But yes, the filter on an S-VHS deck are worth it, and much better than regular VCRs.Want my help? Ask here! (not via PM!)
thanks for all your quick answers. Between this forum and DigitalFAQ i have received so much info. Will try to find a JVC 9800.Originally Posted by lordsmurf
Are all adapters the same, cause my came with my camcorder and its a JVC camcorder. And thanks for that info cause I've used my adapter in my JVC VCR, never ate the tape I was lucky I guess. -
Since using a "c" adapter may not be a good idea...Let's say I play the vhs-c tape through my camcorder and send the output to a s-vhs deck and then output to the capture card, tv, etc... Does the s-vhs still filter the signal, or do you have to play the tape on the s-vhs for the filters to be effective? Ditto for a s-vhs with a tbc?Originally Posted by lordsmurf
Thanks. -
You have to be playing the tape on the vcr for the TBC and other features to work. For what it is worth, when I tried using my HR-S9900U for a VHS-C tape from my camcorder, it had too much jitter even with the TBC on, etc. It played better on some of my other VCRs. But YMMV.
Best method for capturing VHS?
By blud in forum Newbie / General discussionsReplies: 7Last Post: 6th Apr 2012, 05:06 -
Done capturing my VHS, what now?
By Akerhage in forum Video ConversionReplies: 31Last Post: 27th Jul 2011, 09:37 -
capturing vhs to hdd
By zulubase in forum Capturing and VCRReplies: 2Last Post: 20th Feb 2010, 18:00 -
capturing from VHS
By halbblah in forum RestorationReplies: 4Last Post: 1st Nov 2009, 17:35 -
Capturing VHS using All In Wonder HD
By ukcolonelcolin in forum Capturing and VCRReplies: 14Last Post: 2nd Dec 2008, 10:32
