Closed Thread
  1. Hi there,
    I just downloaded a file and inside the file are 2 folders CD1 and CD2 when i click on CD1 there are a bunch of files in there, named vcd.fnlts01.r30------up to-----vcd.fnlts01.r54,
    Then there are awhole bunch of .RAR files named vcd.fnlits01, probably about 30 with that identical name
    CD2 is pretty much the same just with an 02.
    I cant figure out how to get a .bin or .cue file from this? Which is the only way im really use to doing this.
    Any help very much appreciated
    thanks
  2. Thats an archived RAR file structure. Find the ".rar" extension with the lowest number....sometimes they are {.rar, .r01, .r02..etc} or sometimes they will start from .r01 and then .r02..etc
    Make sure all parts are all in the same folder then double ckick on the first part and you will see what is contained and then basically extract just like a regular rar file.
  3. the problem is all the .RAR files have the exact same name, so i dont know which is the lowest number
    All the .RAR Files are named vcd.fnlits01
    buy the movie.
