Hi
My question is pretty straightforeward, and hopefully the answer will be too, but somewhow, I dont see that it will.
I would like to know if its possible to resize a widescreen DVD to Fullscreen without stretching the image.
I realize that if it were possible, that I would lose some of the frame on each side (left and right), I can deal with that.
I would just 'zoom' but... well this question has been rattling around in my head for a while now, and I'm quite curious if there is a solution complex or otherwise.
thank you for your time.
DVD_NDN
scratch the surface off a cynic - you will find a disillusioned idealist.
Hello,
Yes you could do it with tempgenc.
Yes it will be locked into the center of the screen losing the edges. If it's a really wide movie like Star Wars (2.35 to 1) it can be quite a loss since you can't easily make your own pan and scan, just a crop.
You can do it but it would be easier to buy the full screen version of the movie to have it down properly (if you like fullscreen that is).
Do a forum search and you'll find plenty of threads on the conversion.
Good luck.
hi
holy crap, that was way fast.
Thanks alot for the tip.scratch the surface off a cynic - you will find a disillusioned idealist.
Dvd player plays widescreen dvds in fullscreen on widescreen tv
By Fireworks_at_Dawn in forum Newbie / General discussionsReplies: 35Last Post: 24th Sep 2012, 08:24 -
Widescreen shows up on the PC but as fullscreen on the TV?
By Moontrash in forum Authoring (DVD)Replies: 8Last Post: 17th May 2010, 17:26 -
Fullscreen vs. Widescreen: why still airing new content in fullscreen ?
By vhelp in forum DVB / IPTVReplies: 56Last Post: 2nd Oct 2009, 14:54 -
Widescreen to fullscreen conversion
By F8L23 in forum Video ConversionReplies: 15Last Post: 13th Dec 2008, 12:38 -
Widescreen To Fullscreen
By OG24 in forum Newbie / General discussionsReplies: 10Last Post: 11th Aug 2007, 15:51
