Hello,
Try watching the ifo file with a dvd player software like powerdvd. Use dvd mode. Then if it plays normally the files should be compliant. Check the configuration tab to read the specificaitons. They should say mpeg2 video.
If so than you should be able to put them in a video_ts folder and burn the folder (since you have ifo and bup files already). Use a rewritable disc as a test.
no video_ts.ifo? https://www.videohelp.com/dvd#struct , you can try copy the video_ts.bup to a new file and name it video_ts.ifo
or try http://users.pandora.be/rudy.stremersch/createifo.html -
Thanks! You're right, there was no vide_ts.ifo; I copied the .bup one and renamed it and it accepts now. I guess it got deleted somehow.Originally Posted by Baldrick
DVD compliant and 60fps?
By fearmyrage in forum Authoring (DVD)Replies: 11Last Post: 28th Apr 2012, 23:51 -
How do I make an MPEG-2 dvd compliant file into a authored dvd?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 13Last Post: 12th Mar 2009, 16:10 -
making a compliant resolution mpeg2 file from a non-compliant .mkv file
By dwisniski in forum Video ConversionReplies: 1Last Post: 7th Mar 2008, 07:49 -
Anyway to make a non compliant disc compliant?
By zanos in forum Authoring (DVD)Replies: 9Last Post: 23rd Feb 2008, 11:46 -
question about VOB compliant files to make DVD
By jimdagys in forum Authoring (DVD)Replies: 3Last Post: 25th Nov 2007, 02:05
