Just wondered if anyone has a tried and tested method of authoring srt subs as selectable on a dvd. I usually go down this route:
1. Srt to ssa with subtitle workshop
2. Ssa to son with MaestroSBT
3. Author with DVDMaestro
Problem is that the subs always run off the bottom of the screen. Don't believe there can be a problem with the srt file as i dont think they contain any positional information. Have tried srt2sup and then rejig to no avail. Have had success with DVDSVCD but this doesn't like the avi i'm working with at present, it only outputs a very small .mpv file. So i've now converted with TMPGenc and if anyone can help out with muxing mpv, ac3 and correct positioning of srt files i'll be eternally grateful.
Regards, adyf.
Change the position in maestrosbt. Open the ssa, click on Styles, Select Default, Edit Style and change the Bottom Margin(increase it to around 44). Click on Edit->Preview to check that subs are higher in the picture.
How to demux .srt from mkv, then convert .srt to .smi and mux .smi to mkv??
By narayanan in forum SubtitleReplies: 1Last Post: 7th Aug 2010, 22:49 -
Subtitles Tools (SUB to SRT 1.33) for OCR Chinese Txt to SRT
By dennis3377 in forum SubtitleReplies: 0Last Post: 10th Dec 2009, 00:46 -
SRT SUB
By sg999 in forum SubtitleReplies: 13Last Post: 2nd May 2009, 22:27 -
Working with .sup and .srt
By ma2kp in forum SubtitleReplies: 2Last Post: 8th Dec 2008, 21:34 -
.sub to.srt?
By Hank Kinsley in forum SubtitleReplies: 9Last Post: 14th Aug 2007, 12:25
