  1. Which transitions on slide show movie maker are slow? Is there a list somwhere? i.e. Blur-Fade takes a couple of minutes to compile. Any other ones out there? thanks.
    Here's a sample from settings.ini
    [FADING_EFFECTS]
    Additional Dissolve=0
    Blur-Fade=1
    Diagonal-Stretch-Right-Top=0
    Vibration=0
    (from this list, only Blur-Fade is slow). Post your list if u've compiled one. thanks.
  2. Member mastersmurfie's Avatar
    May 2003
    just tried Blur-Fade...with only two pics!! took almost 8 minutes to compile...
    and here's my settings.ini:
    [FADING_EFFECTS]
    Bottom-Top-Move=0
    Bottom-Top-Side-Push=0
    Bottom-Top-Wipe=0
    Box-Wipe=0
    Box-Wipe-Reverse=0
    Center-Fan (Left and Right)=0
    Diagonal-Stretch-Right-Bottom=0
    Flow-Wipe-Effect=0
    Horizontal-Close-Wipe=0
    Iris (Round)=0
    Random Circle Cross Dissolve=0
    Right-Left-Side-Push=0
    Right-Left-Wipe=0
    SandClock-Effekt-Blocked (Right-Left)=0
    Splitted Circle (In-In)=0
    Splitted Circle (In-Out)=0
    just a thought, but maybe try a different transition than Blur-Fade...
    mastersmurfie
    just a thought
    mastersmurfie
  3. hey,
    from the settings.ini, i think that any transition effect w/ a "=1" next to it means that it's disable during 'random fadings' settings won't be used during the random fadings. Thus, my settings.ini had a "Blur-Fade=1" on it. i'm pretty much looking for any other effects that need a =1 next to them, since those are the ones that end up taking a couple of minutes to render. yeah, 8 minutes for one transition stinks.
    on a side note, anyone know how to coordinate the slide show w/ music so that intead of having fixed frames on each slide, it automatically sets the values so that the slide show ends when the song ends? thanks.
