I need to know how to join an xvid movie thats in 2 parts. I tried vdub but it needs a plugin i can't seem to find. If someone could point me in the right direction it would be great.
Well The film Machine can do that plus convert the avi to vcd/svcd/dvd using any one of these encoders (CCE Quenc & Canopus Procoder). If you just want to join the the 2 avi's just do this. Add your source avi's to in The Film Machine let it run & join the avis & sync the audio. Just before it's about to start the converion process. Abort the program then look in the Film Machines directory for a temp file. It'll probably have a non recognizable name but it's in there. The file size will also give it away. Just look for a temp avi file the size of your 2 avi's combined. Well i hope that helps you...
Trying to encode a clip to XviD to join another using VirtualDub ...
By Phat J in forum EditingReplies: 21Last Post: 5th Jun 2012, 02:08 -
How to join back 2 xvid files encode by autogk
By warresg in forum DVD RippingReplies: 1Last Post: 6th Nov 2010, 02:59 -
Join Avi (xvid) files together
By SpyJoe in forum EditingReplies: 11Last Post: 26th Aug 2009, 17:44 -
LOAD CLICK AND LOW SOUND at join of 2 avi xvid ac3 using vitualdub
By hawklight in forum EditingReplies: 0Last Post: 15th Jul 2007, 08:44 -
I Can't Join 2 XviD Videos together!
By Nitro89 in forum EditingReplies: 10Last Post: 26th Jun 2007, 15:08
